Re: '4 door Barracuda' goes to auction
[Re: ChryCoGuy]
#3111867
01/14/23 01:43 PM
01/14/23 01:43 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
Man, some of you guys are harsh. After reading some of the sanctimonious comments in this thread, you'd think that he was spending your money and making you do the work on it... The man had a vision and he managed to follow it through before he passed. Have some respect for that. Many of us will likely leave our families with a bunch of cars and car stuff that our families will have to deal with later... it's not uncommon. And our families will likely only get a fraction out of it from what we spent on the junk - I've seen some cases where it all just went to the scrap yard. A life's worth of collecting, all scrap metal to go into the next electric Hyundai... think about it. Regardless... on the topic of the 4-door Barracuda itself, I'm sure the idea was tossed around at the product planning/styling dept. brainstorming sessions, even if it never made it to clay. Ford and GM were considering it, why wouldn't the Chrysler Corp.? If I were brainstorming this project, I would have aimed the marketing at somebody who really wanted a sporty car like a Barracuda, and not a tall frumpy looking sedan (otherwise they could just have bought a Satellite and called it a day). The concept drawing that was floating around at the time of a 4 door hardtop with low roofline seemed like a more likely candidate, rather than where Dave ended up going. Just my opinion, but the end result looked like what might have happened if the engineers won their argument over the styling department, and upper management insisted on more headroom for back seat passengers (and perhaps better structural integrity as offered by a sedan vs a hardtop). Here's the drawing that was floating around (which I thought would more likely have been what Chrysler would have pursued): For me, it was interesting. I followed the build online and was amazed at the workmanship and attention to detail that was put into it... even if I didn't really like the final result aesthetically. It only adds to the hobby as far as I'm concerned, and I really have no time for anyone who wants to cut a guy down (especially after he's dead) for following his dream and vision, even if it's not what I would do (not that I would ever have the ability to take on a project like this, to such a high level). Just my , FWIW. If you do something wrong,no matter how much detail you put into it at the end of the day it's still wrong. The right way to do it was to use the Cuda roof,extend it using the center of a second Cuda roof,cut the door window frames off the Coronet doors and have glass made to fit the roof properly. If anyone could have pulled this off correctly it was Dave,his company makes glass. He decided to do it the easy way using the stock Coronet glass and door window frames that in no way align with the roof line of a Cuda. He should have done the pillarless model with the right roofline like the drawing. Then he got pissed off at everyone who called him out on the car for the roof looking effing goofy,well it does look effing goofy. The roof lines of the two cars aren't even close,and the curved A pillars that get wider as they go up look like crap against the Cuda straight windshield moldings that end six inches below the side glass height!
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: Redbird]
#3111873
01/14/23 02:07 PM
01/14/23 02:07 PM
chargervert
It's not meanness it is just stating the obvious facts on the build. All of Daves other restorations were top notch OEM gold quality builds as were the products he made and offered to our hobby. Dave's passing is truly a loss to everyone involved in the hobby. This build however was a swing and a miss.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#3111875
01/14/23 02:09 PM
01/14/23 02:09 PM
Posts: 11,076 Berlin, N.J.
abodyjoe
Berlin, N.J.
[quote=ChryCoGuy]
If you do something wrong,no matter how much detail you put into it at the end of the day it's still wrong. The right way to do it was to use the Cuda roof,extend it using the center of a second cuda roof,cut the door window frames off the Coronet doors and have glass made to fit the roof properly. If anyone could have pulled this off correctly it was Dave,his company makes glass. He chose to do it the easy way instead of doing the pillarless model with the right roofline like the drawing. Then he got pissed off at everyone who called him out on the car for the roof looking effing goofy,well it does look effing goofy. The roof lines of the two cars aren't even close,and the curved A pillars that get wider as they go up look like crap against the Cuda straight windshield moldings that end six inches below the side glass height! never saw it from that angle. my god that is bad. it really is the perfect example of just because ya can doesn't mean you should.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: abodyjoe]
#3111878
01/14/23 02:17 PM
01/14/23 02:17 PM
chargervert
[quote=ChryCoGuy]
If you do something wrong,no matter how much detail you put into it at the end of the day it's still wrong. The right way to do it was to use the Cuda roof,extend it using the center of a second cuda roof,cut the door window frames off the Coronet doors and have glass made to fit the roof properly. If anyone could have pulled this off correctly it was Dave,his company makes glass. He chose to do it the easy way instead of doing the pillarless model with the right roofline like the drawing. Then he got pissed off at everyone who called him out on the car for the roof looking effing goofy,well it does look effing goofy. The roof lines of the two cars aren't even close,and the curved A pillars that get wider as they go up look like crap against the Cuda straight windshield moldings that end six inches below the side glass height! never saw it from that angle. my god that is bad. it really is the perfect example of just because ya can doesn't mean you should. The rear window is even worse.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#3111881
01/14/23 02:26 PM
01/14/23 02:26 PM
chargervert
My post should not be taken as meanness,it should be taken as reconstructive criticism,because I just laid out the complete blueprint for the new owner on how to fix the car and make it look like a car the factory actually would have built. Plus this can be achieved with minimal paintwork on the tops of the doors and most of the work would be under the vynal top.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: Kern Dog]
#3111897
01/14/23 03:14 PM
01/14/23 03:14 PM
chargervert
As I said above KD,Losing Dave was a big loss to the hobby. I broke down the build,and stated that Dave had the means and access to get the right glass made for the car. Nothing against the craftsmanship,more so about the approach. I have things on my own builds that I would do different if I were to do them again. We learn and improve as we progress in the hobby. Dave set his own bar so high that people were left baffled by this build.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#3111934
01/14/23 06:21 PM
01/14/23 06:21 PM
Posts: 6,321 o
ChryCoGuy
o
It's not meanness it is just stating the obvious facts on the build. All of Daves other restorations were top notch OEM gold quality builds as were the products he made and offered to our hobby. Dave's passing is truly a loss to everyone involved in the hobby. This build however was a swing and a miss. I didn't take your comments as meanness, actually. There's a difference between constructive criticism of one's work and actual shots at his character. IMHO some cross the line and I don't have a problem with calling it as such. Everybody has a right to their opinion, and I posted my honest thoughts on it, whether people agree with them or not. As far as how his family felt about it or what he should have spent his money on or whatever, that's just BS IMHO, and that's what I was talking about.
[Re: chargervert]
#3111983
01/14/23 09:39 PM
01/14/23 09:39 PM
Posts: 16,818 Between Houston & Galveston TX
SattyNoCar
[quote=ChryCoGuy]
John
[Re: Dart 500]
#3112022
01/14/23 11:55 PM
01/14/23 11:55 PM
chargervert
If i had more money than brains I'd buy it, cut the roof off it and make it a proper 4 door hardtop. I remember controversy when it was being built but I never paid attention, looking at it now - man does it ever look wrong, and I assume the builder knew that but was too $$$ invested to turn around. I wasn't trying to be a jerk about it,but I was spelling out what was clearly done wrong and what was needed to make it right. Every car Dave had done before was OEM Gold level,which is not something that is easily achievable.!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#3112033
01/15/23 01:01 AM
01/15/23 01:01 AM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
not to pile on the wheelbase missed the mark also ..... 1970A - Duster 2dr 108" - Valiant 4dr 108" B - Belvedere 2dr/4dr 116" & station wagon 117" C - Fury 2dr/4dr 120" & station wagon 122" E - Barracuda 2dr 108" & ECS 4dr 120"
[Re: 6bblgt]
#3112154
01/15/23 02:58 PM
01/15/23 02:58 PM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
I just found out today that the car sold at the auction for $121,000. I didn't think it would sell for that much
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
[Re: SportFuryS/23383]
#3112179
01/15/23 04:32 PM
01/15/23 04:32 PM
chargervert
I just found out today that the car sold at the auction for $121,000. I didn't think it would sell for that much I asked my friend who knows the seller of the car,why he bought the car in the first place,he said he like weird cars that are different,I said that one sure fits that description perfectly!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: McCandlessboy]
#3112279
01/15/23 09:55 PM
01/15/23 09:55 PM
chargervert
I'm not convinced they had a bid at 100k. They opened around 300 and started dropping of course. They stayed FOREVER at 100k asking 110. As soon as they got 110, it was a pretty quick hammer. I was hoping it would get hung just to see what they'd do. It sounds like someone got stuck with that monstrosity!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
