No oil pressure after oil change
#3086480
10/16/22 01:41 PM
10/16/22 01:41 PM
Posts: 1,553 Sweden
71redcuda
Sweden
Oil pressure lamp is on after i changed oil & filter (wix) in my aar cuda.
I started the car just before the change and all was fine..
No other work was done.
after the change the oil lamp was on for maby 5-10sec before i turned the car off.
I replaced the filter again with a new one and tried to start again.. with no difference..
Any suggestions ?
Re: No oil pressure after oil change
[Re: Cab_Burge]
#3086490
10/16/22 02:06 PM
10/16/22 02:06 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I see it's a small block, is filter relocated or at angle? How much oil can you put in filter and install? I have mine relocated vertically so I can completely fill filter and install. Seems light may be on for 5-10 normally to gain pressure after change. No gauge? Any engine noise?
One of the best things I ever did on my 408 small block was relocate filter up front behind bumper attached to rad support with nice stainless lines. No dumping of oil on headers and I can use taller filter and fill filter completely before install, and oil changes so much easier!
I stopped using WIX filters long time ago. No longer highly rated and stopped be produced in USA and I had heard of some internal clogging. Amsoil, Royal Purple, and K&N get high ratings. Not saying you have a clogged filter necessarily just some added info.
Edit: I think I see the filter in it's stock location on 340 with 90 degree adapter. My screen kind of dark. I'd consider relocation! I know you may want stock appearance and I can understand but it's so much better.
Facts are stubborn things.
[Re: larrymopar360]
#3086542
10/16/22 03:21 PM
10/16/22 03:21 PM
Posts: 1,553 Sweden
71redcuda
Sweden
Yes filter is in stock position. I filled it half way up when i installed it..
Any more and the oil will drip out because of the angle.
How long before building up the pressure?
Dont want to risk anything..
[Re: 71redcuda]
#3086575
10/16/22 04:55 PM
10/16/22 04:55 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Dont want to risk anything.. Before I relocated mine I would sometimes have lifter noise for about 10 seconds and then it would start quickly quieting. I wouldn't feel comfortable any longer than that. Cut that first filter open if you still have it. Take a saws all and cut it right in the middle just for heck of it and make sure you don't have bad batch of WIX. I would. No harm. I doubt it's that but simple enough to check.
[Re: larrymopar360]
#3086586
10/16/22 05:44 PM
10/16/22 05:44 PM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
At this point, you have to pull the distributor and drive, and prime the pump. Turn the ignition on and see if the light goes out.
Did it make any noise? Any doubts, take the sender out and plug a wet gauge in to see what's really going on. Don't start it until it's right.
[Re: CMcAllister]
#3086607
10/16/22 06:51 PM
10/16/22 06:51 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Did it make any noise? Any doubts, take the sender out and plug a wet gauge in to see what's really going on. Don't start it until it's right. Yes, I'm wondering about the noise too. Hasn't said but I feel certain there'd been lifter noise if oil wasn't getting pumped. Like you said, prime with a drill. I'd still cut the previous filter open and see what's inside and yes check the light's operability.
[Re: CMcAllister]
#3086656
10/16/22 09:11 PM
10/16/22 09:11 PM
Posts: 4,958 WI
Dcuda69
WI
Did it make any noise? Any doubts, take the sender out and plug a wet gauge in to see what's really going on. Don't start it until it's right. Agree! NEVER do any lube system repairs without putting a mechanical gauge on the system and measuring actual system pressure. Lights and electrical gauges are useless!
[Re: metallicareload]
#3086716
10/17/22 06:33 AM
10/17/22 06:33 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Oil pressure should come up and light go out in a few seconds. 30 seconds? Not right. Wet gauge. Or stick a new switch in it. Spin the pump with a drill. Don't start or crank it until you find the issue. It's already been run enough, if it really doesn't have pressure.
I have had enough senders go bad to suspect a bad one in your situation.
[Re: CMcAllister]
#3086797
10/17/22 10:55 AM
10/17/22 10:55 AM
Posts: 10,757 North Dakota
6PakBee
North Dakota
Did it make any noise? Any doubts, take the sender out and plug a wet gauge in to see what's really going on. Don't start it until it's right. Agreed. You can tell by the load on the priming drive if you have oil pressure or not. You should also be able to see oil flowing around the distributor gear bushing.
[Re: 71redcuda]
#3086823
10/17/22 11:47 AM
10/17/22 11:47 AM
Posts: 15,501 Omaha Ne
TJP
Omaha Ne
The oilfilter had oil in it when i changed it the first time so i think it might be the oil sending unit. Do not replace the sending unit and start the motor to see if the sending unit suddenly took a dump or you may risk engine damage> It's more effort but the correct and only way to address the issue at this point is as everyone has suggested, Pull the distributor and oil pump drive. Install a mechanical gauge and run the pump with a priming rod and drill motor. the correct direction is CW. (clockwise) ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: 6PakBee]
#3086861
10/17/22 01:39 PM
10/17/22 01:39 PM
Posts: 4,701 Wichita
GY3
Wichita
Did it make any noise? Any doubts, take the sender out and plug a wet gauge in to see what's really going on. Don't start it until it's right. Agreed. You can tell by the load on the priming drive if you have oil pressure or not. You should also be able to see oil flowing around the distributor gear bushing. Yep, you will feel it "grab" and pull the drill down once it gets pressure. I've had a couple of BB's lose their prime for no good reason. Pull the distributor, intermediate shaft and primed them with the drill. No further issues.
[Re: TJP]
#3087111
10/18/22 10:40 AM
10/18/22 10:40 AM
Posts: 1,553 Sweden
71redcuda
Sweden
The oilfilter had oil in it when i changed it the first time so i think it might be the oil sending unit. Do not replace the sending unit and start the motor to see if the sending unit suddenly took a dump or you may risk engine damage> It's more effort but the correct and only way to address the issue at this point is as everyone has suggested, Pull the distributor and oil pump drive. Install a mechanical gauge and run the pump with a priming rod and drill motor. the correct direction is CW. (clockwise) Will do, thanks!
