6 Pack Vacuum Hose #3085489
10/12/22 03:03 PM
10/12/22 03:03 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
What is the correct size of vacuum hose to use on the 6 Pack set up ? Thanks Kevin
Re: 6 Pack Vacuum Hose [Re: B5TA] #3085599
10/12/22 09:59 PM
10/12/22 09:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'll guess 1/8" ID beer
Re: 6 Pack Vacuum Hose [Re: TJP] #3085669
10/13/22 05:34 AM
10/13/22 05:34 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The Vacuum fittings coming out of the carbs is .1875 which is 3/16. I have not bought any in awhile but I would think 3/16 is the correct size.
Re: 6 Pack Vacuum Hose [Re: fastmark] #3085709
10/13/22 09:45 AM
10/13/22 09:45 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
You are correct on fitting size, I've been to EVERY local part store in my area and nobody carries 3/16". I've noticed on a lot of occassions they use the next size under hose, to go on the fitting . So I'm thinking 5/32" hose to go on the 3/16" fitting ???? Thanks, Kevin
Re: 6 Pack Vacuum Hose [Re: B5TA] #3085716
10/13/22 10:08 AM
10/13/22 10:08 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
We stock the 3/16" vacuum hose as we use it for the reproduction vacuum hose kits that we build for the 68-69 Chargers and Super Birds.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
