318 engine question ?? #308172
05/04/09 10:49 PM
05/04/09 10:49 PM
MA.
P
plymguy Offline OP
plymguy  Offline OP
P
MA.
Is there any difference between a 318 car engine and a 318 truck engine? Would a truck engine from say a '73 to '79 bolt up to my '67 Fury 727 transmission? Thanks for any info.
John
Re: 318 engine question ?? [Re: plymguy] #308173
05/05/09 02:57 AM
05/05/09 02:57 AM
the 318 truck eng would have a slightly better crank but it'd be the same eng. yes it will bolt up to your 67 727, only caveat is there was a front pump spline change in iirc 67(or8) so use the correct TC.
Re: 318 engine question ?? [Re: RapidRobert] #308174
05/05/09 07:42 AM
05/05/09 07:42 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
when you put a truck engine in a car you will need to put the car oil pan/pickup on the truck motor.
