SB rocker shaft hold down washer/spacer ?'s #308141
05/04/09 10:35 PM
05/04/09 10:35 PM
Medford OR
FrankenScamp Offline OP
Medford OR
It would appear I installed the hold downs in the wrong locations during assembly. The 2 wider pieces are supposed to be in the #2 and #4 positions.
Would this mess up the proper oil flow to the rockers/pushrods?
Did I ruin my rockers? there was noise and there is visible wear but not so much I that can feel it.
Make sense? Thanks!!
Re: SB rocker shaft hold down washer/spacer ?'s [Re: FrankenScamp] #308142
05/04/09 10:37 PM
05/04/09 10:37 PM
harmony pa
rampage08 Offline
rampage08  Offline
harmony pa
some of those you have to grind the edge off for propper spaceing
Re: SB rocker shaft hold down washer/spacer ?'s [Re: rampage08] #308143
05/04/09 10:38 PM
05/04/09 10:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Should be no reason to grind the spacers. They go in a certian order and fit with no adaption necessary. Won't hurt the oil flow. What shows wear?
Re: SB rocker shaft hold down washer/spacer ?'s [Re: stumpy] #308144
05/04/09 10:44 PM
05/04/09 10:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Very true.
Re: SB rocker shaft hold down washer/spacer ?'s [Re: stumpy] #308145
05/04/09 10:44 PM
05/04/09 10:44 PM
harmony pa
rampage08 Offline
rampage08  Offline
harmony pa
if you use stock hold downs with after market shafts and rockers they need ground. i just went threw that my self. sorry didnt mean grind spacers
Re: SB rocker shaft hold down washer/spacer ?'s [Re: rampage08] #308146
05/04/09 11:02 PM
05/04/09 11:02 PM
Medford OR
Medford OR
all stock....
