Re: Timing on Race Gas for 6.4
[Re: Dyno1]
#3079229
09/21/22 08:28 AM
09/21/22 08:28 AM
Posts: 1,185 Loudoun County, VA
Brad_Haak
Loudoun County, VA
May be worth a call to Dave Weber at MMX, since he's done a lot of G3 Hemi work. He's the Weber in the former Ritter & Weber race team.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Dyno1]
#3079543
09/22/22 09:35 AM
09/22/22 09:35 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
I have a 6.4 that is raced in NHRA/NMCA Stock Eliminator. I am using a Holley Dominator system on the car. 2019 1320 Challenger. I use a leaded race gas (Renagade 116). What has anyone experienced with ignition timing? I use 26 - 27 degrees total above 6000rpm, generally finish line rpm about 7600-7700. I have been told that is max timing to use because of detonation above 27*. Anyone run 28 to 30* of timing and did you pick anything up? Thanks, Dyno How did you do the Holley system & not get the factory functions of the car messed up, I have been trying to find a set up that will have wide band o2 fuel control & tuning on my 2020 T/a 392 ?
[Re: Dyno1]
#3080000
09/23/22 02:53 PM
09/23/22 02:53 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
To make the most HP you can on your motor you don't want to use the highest octane gas out there, it is a waste of money and fuel. I would try either C10 or C11 if you insist on running leaded race fuel. The least octane fuel you can run in that motor without detonation will make the most power and make the car run the fastest I've been there done that with my old M.W. 1963 Plymouth stocker
[Re: CSK]
#3080055
09/23/22 05:24 PM
09/23/22 05:24 PM
Dyno1
I have a 6.4 that is raced in NHRA/NMCA Stock Eliminator. I am using a Holley Dominator system on the car. 2019 1320 Challenger. I use a leaded race gas (Renagade 116). What has anyone experienced with ignition timing? I use 26 - 27 degrees total above 6000rpm, generally finish line rpm about 7600-7700. I have been told that is max timing to use because of detonation above 27*. Anyone run 28 to 30* of timing and did you pick anything up? Thanks, Dyno How did you do the Holley system & not get the factory functions of the car messed up, I have been trying to find a set up that will have wide band o2 fuel control & tuning on my 2020 T/a 392 ? Race car only. None of the factory computers are used.
[Re: Cab_Burge]
#3080057
09/23/22 05:26 PM
09/23/22 05:26 PM
Dyno1
To make the most HP you can on your motor you don't want to use the highest octane gas out there, it is a waste of money and fuel. I would try either C10 or C11 if you insist on running leaded race fuel. The least octane fuel you can run in that motor without detonation will make the most power and make the car run the fastest I've been there done that with my old M.W. 1963 Plymouth stocker I also race a 1968 Barracuda in SS/AH, so it is easier to carry just one brand of fuel. I have tried VP C12 and there was no difference.
[Re: Dyno1]
#3080067
09/23/22 05:55 PM
09/23/22 05:55 PM
CSK
Pattison Texas
I have a 6.4 that is raced in NHRA/NMCA Stock Eliminator. I am using a Holley Dominator system on the car. 2019 1320 Challenger. I use a leaded race gas (Renagade 116). What has anyone experienced with ignition timing? I use 26 - 27 degrees total above 6000rpm, generally finish line rpm about 7600-7700. I have been told that is max timing to use because of detonation above 27*. Anyone run 28 to 30* of timing and did you pick anything up? Thanks, Dyno How did you do the Holley system & not get the factory functions of the car messed up, I have been trying to find a set up that will have wide band o2 fuel control & tuning on my 2020 T/a 392 ? Race car only. None of the factory computers are used. Thank you for the reply !!!! what class in stock do these cars fit in ?
[Re: Dyno1]
#3080878
09/26/22 04:03 PM
09/26/22 04:03 PM
CSK
Pattison Texas
The car fits in A/SA. Best ET/MPH is 9.92 @133. Minimum weight of 3470 lbs. WOW !!!!! Thank you !!!!!!
