Re: looking for info on connecting rods, H beams.
[Re: 440Jim]
#3077995
09/16/22 11:50 PM
09/16/22 11:50 PM
Posts: 4,457 Washington
madscientist
Washington
Going off memory from previous import rod discussions...
No, they don't ALL come from the same factory; there are some very distinct differences between some brands in how they're machined when you compare them up close, Brad is right, they are different in both dimensions and machining precision. Look at the differences in the web thickness, 0.080" to 0.098"; and the beam widths are different too. NOTE: These dimensions may vary from the same brand with different length rods. This^^^^is because each company can pick what profile they want for the rods. Last time I checked (probably 4 years ago) there were TWO and only TWO factories making connecting rods. That was IT. So all that [censored] comes out of one of two factories. And, I couldn’t care less what name is on the box, every rod needs to be checked for bore sizes and such. All rods should come .0005 under minimum on the both bores so the machinist building the engine can finish them to size. No way do I want the rods to come any other way.
[Re: madscientist]
#3078649
09/19/22 09:21 AM
09/19/22 09:21 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
No matter what name is on them, have them checked. I have a set of Manley H beams that needed resizing before they could be used. Just my opinion, I'd have those rods checked out by your machinist and reuse them. The KB pistons are fine as long as you gap the rings correctly.
[Re: 440lebaron]
#3078827
09/19/22 06:19 PM
09/19/22 06:19 PM
Posts: 2,049 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
cannot tell if that's a ARP bolt, if they are there not 440 source, I have a set of new (latest designed)383-400 rods from 440 source at shop if you need a photo, if anybody wants them $150 free shipping
I just purchased a set of 440 Source rods from a member on here that came with ARP 2000 bolts installed from 440 source. They are a few years old though. They also have "440 Source" etched on the flat side of the beam. Brian
