Page 4 of 4 1 2 3 4
Re: battery draining. Can't find the draw [Re: A990] #3079695
09/22/22 05:05 PM
09/22/22 05:05 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Originally Posted by A990
I parted a 71 Dart years ago that had a fried underdash harness. I kept it for redoing the one in my 70 and when I opened up the fried one, I found the brake warning circuit wired wrong.
The downleg wire after the light was only connected to the e-brake switch, but the low fluid circuit was joined at the hot side.
Imagine trying to troubleshoot a hot wire smell that only occurs when the brake fluid is low, much less connecting those two dots!
You had a 70/71 Dart with a low brake fluid switch?
Re: battery draining. Can't find the draw [Re: Sniper] #3079773
09/22/22 09:45 PM
09/22/22 09:45 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I can't remember if the 70 had one, but the 71 definitely did. It was built into the junction block.
Page 4 of 4 1 2 3 4
