Which Tire? #307333
05/04/09 10:29 AM
05/04/09 10:29 AM
PORT ALBERNI , BC., CANADA
superwrench Offline OP
My 29x10 15 Hoosiers just won't bite any more. It seems the sidewalls look too wrinkled so I think they're toast. The 60' has gone all to hell!
If I stay with the Hoosiers, would a QTP 29x11.50 give me enough bite, or should I stick with a drag tire?
These tires only have about 80 passes on them. Sure seems that they went away quick to me.
The car is a 71 Challenger 496, 3700# race weight.
Re: Which Tire? [Re: superwrench] #307334
05/04/09 10:55 AM
05/04/09 10:55 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
MT drag radial street tire works for me
i run 325/50
Re: Which Tire? [Re: sixpackgut] #307335
05/04/09 10:57 AM
05/04/09 10:57 AM
an8sec70cuda Offline
i run 325/50
295-65 ET Street radials here. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Which Tire? [Re: an8sec70cuda] #307336
05/04/09 01:43 PM
05/04/09 01:43 PM
I don't think the 325/50's will fit in my wheel opening without rubbing.
The 295/65's would be close.I could always put the front spring eye on the bottom hole for a bit more.
Re: Which Tire? [Re: superwrench] #307337
05/04/09 04:18 PM
05/04/09 04:18 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I'd go with a M/T either drag slick or ET tire..both work extremely well and last ALOT longer than hoosiers.
Re: Which Tire? [Re: DusterKid] #307338
05/04/09 04:41 PM
05/04/09 04:41 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Hoosier QTP's 29 x 11.5 and they hook great for me. And I have been driving on them for almost 2 years. Ron
Re: Which Tire? [Re: 383man] #307339
05/04/09 06:08 PM
05/04/09 06:08 PM
I take it those are the 17700's .
I'd really like to try them , but price is what's holding me back.
They want $350 each CND for those tires . I can buy 295/65 R15 M/T ET street radials up here for $245 each. The M/T's are a 30" tire and that's gonna get close to my wheel well lips for sure.
My last set of Hoosiers 29x10's sure went south in a hurry. My last set of M/T bias slicks lasted me 2 seasons.....the Hoosiers lasted 1 .
Re: Which Tire? [Re: an8sec70cuda] #307340
05/10/09 01:47 AM
05/10/09 01:47 AM
i run 325/50
AMEN!!!
I put 295/65R15 ET street M/T's on Friday morning...went to the track and ripped off the best time BY FAR this Pink Turd has ever done!!!!
It's a short track...but a 4.478 330 time is the quickest it's ever gone. 15.5 lbs pressure...a little light as to what most of you guys say...but that's where it hooked. 17 was WAY too much!!
Thank's for the advice!
