A Body front coil over spring rate #307272
05/04/09 08:44 AM
05/04/09 08:44 AM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
my duster weighs 3230 lbs
don,t know the front/rear bias
currently running a 450 lbs spring with plans to change to a 400 lbs spring
What rate spring are you a body guys using?
WAXER
Re: A Body front coil over spring rate [Re: QWK_ENUF] #307273
05/04/09 08:20 PM
05/04/09 08:20 PM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
currently 350's but I think 400's would be better, mine is only 3050lbs. Oh and I have a small block with eddy heads
Re: A Body front coil over spring rate [Re: QWK_ENUF] #307274
05/04/09 09:24 PM
05/04/09 09:24 PM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
600
Re: A Body front coil over spring rate [Re: MoparPitBull] #307275
05/04/09 09:39 PM
05/04/09 09:39 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
at 2961 I am running 350's also
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
