Re: 318 to 360
[Re: cudaman1969]
#3070304
08/21/22 09:47 PM
08/21/22 09:47 PM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
The 318 PCM won't cut it. The van PCM should work if it has the same 60 way connector.
