Re: 87 turismo 5 speed transmission throwout bearing
[Re: JonGottaDemonDad]
#3071515
08/26/22 03:17 AM
08/26/22 03:17 AM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
Yes it should move freely and easily.
#3071521
08/26/22 05:19 AM
08/26/22 05:19 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I am ready to put this transmission back in the car. It is a low-mileage car but the clutch was stuck so I pulled the engine put a new clutch in and throw out the bearing. The linkage in the attached photo does not move very easily. It does move freely but it is kinda stiff.
I did grease all parts of this setup before putting it back on the car but I want to make sure this stiffness is normal.
Anyone with experience that can offer some guidance.
Thanks,
Craig The case gets corrosion behind the bushing. Pull the shaft out, clean it. Gently knock the bushing out, hone the case. Coat both with never seize, reassemble.
"I think its got a hemi"
