fuses are rated for the circuit they are intended to protect.
using a higher rated fuse than the circuit is designed for is not a good idea.
you will have to look further into the tail light branch to see what is causing the fuse to blow.
and will add the following:
It is possible you have a bad batch of fuses, our overseas QC is not always 100%. A 15 amp fuse would normally be used in a circuit that draws ~ 11A max.
Do a current draw on the circuit to see what it's actually pulling. Also there are usually other items that may piggyback on the same circuit so a schematic may be handy to identify what else may be on that circuit causing the problem. keep us posted
