Fan Shroud Options? #306516
05/03/09 03:18 PM
05/03/09 03:18 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
How neccesary are fan shrouds?
Mild 440 with A/C, a new (aftermarket) 4 row brass radiator and a new (aftermarket) flex-fan. The thermostat is a 165. Am I asking for trouble if I don't put a shroud on it? And... did anyone fabricate their own? Any pics or info would be great.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Fan Shroud Options? [Re: BFASTER] #306517
05/03/09 03:20 PM
05/03/09 03:20 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I would shroud it I have a stock shroud for sale if you want it. It has plastic repairs, so I'll sell for like $25+shipping. It's for a B- or C- body radiator with a 22" core.
Re: Fan Shroud Options? [Re: BFASTER] #306518
05/03/09 03:22 PM
05/03/09 03:22 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Here in the valley, you'll want a shroud... I've made a couple, started with cardboard to get a pattern, eventually made one out of steel & the other out of aluminum.. But if your using a brass 26" radiator why not ust a stock type shoud, they are still available..
Re: Fan Shroud Options? [Re: 1_WILD_RT] #306519
05/03/09 03:25 PM
05/03/09 03:25 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Still available where?
Re: Fan Shroud Options? [Re: BFASTER] #306520
05/03/09 03:34 PM
05/03/09 03:34 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Most of the vendors carry it, Try Bill Alpin, or Mopar Ed.. or Ebay
http://cgi.ebay.com/ebaymotors/Mopar-Rad...=item359d3285d2
Re: Fan Shroud Options? [Re: 1_WILD_RT] #306521
05/03/09 03:38 PM
05/03/09 03:38 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Great!! Thanks a lot Randy. BTW, the Super Bee is running. And running real strong! Those new Stealth heads probably have a lot to do with it. Thank you for steering me in that direction.
Re: Fan Shroud Options? [Re: BFASTER] #306522
05/03/09 03:42 PM
05/03/09 03:42 PM
I would (highly) suggest using a 180(or higher) stat. 165(didnt know they came in that temp) is not hot enough to properly atomize your fuel mixture.
Re: Fan Shroud Options? [Re: RapidRobert] #306523
05/03/09 03:54 PM
05/03/09 03:54 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
thats what it is........a 180
Re: Fan Shroud Options? [Re: sharpie] #306524
05/03/09 03:58 PM
05/03/09 03:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Glad to hear it's running, hope to see ya out on the road.. We need to get you to come along on a cruise..
Re: Fan Shroud Options? [Re: BFASTER] #306525
05/03/09 06:02 PM
05/03/09 06:02 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
you may or may not be ok with out one but why chance it. if you can't find an original one make one.
here are pics of the one djvcuda made for me. it helped out quite a bit.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
