Burnout needed for radial tires? #306507
05/03/09 03:11 PM
05/03/09 03:11 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Should be running mid to high 13s. Is a burnout going to be a waste of time and tread before my run? I know it cleans them up a bit, but will they get any stickier by heating them up? size is 215/70/14s. Way smaller than what I need to hook, but it's all I have right now.
Re: Burnout needed for radial tires? [Re: OA5599] #306508
05/03/09 04:09 PM
05/03/09 04:09 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
If they are normal street radials most tracks won't even let you do one because you will drag water all the way up to the line which causes problems for both you and the guy behind you that's making more power and on slicks.
I would just do a dry hop and pull up.
Re: Burnout needed for radial tires? [Re: OA5599] #306509
05/03/09 07:40 PM
05/03/09 07:40 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Our track allows tread tires to burn out, just not in the water. Back in the water to wet the tread, then pull forward out of the water and let 'er rip. Check with the track. How much burn, if at all, will depend on your particular combo. Experiment. We run a KOS class that requires stock street radials. For those of us that overpower street radials, hotter is better. If you need more traction than cold tires give you, more heat will be more bite. I have found that leaving the box at about 200* will give me about 140* tread temp at the line if we don't jack around too long. 140*-160* is about the best range I have found. On my car, below 100* tread temp is no hook at all. If your car doesn't need the tire heat to hook, then spare your tread.
Master, again and still
