Transfer Case Rebuild - '04 1 ton Cummins #3058584
07/12/22 02:19 PM
07/12/22 02:19 PM
Richmond, Indiana
19swinger70 Offline OP
Richmond, Indiana
Hey guys,
Have any of you rebuilt your own transfer case? The case in my truck needs a rebuild, and I'm trying to decide whether to find a place, or do it myself. My case is a NP 271D.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: 19swinger70] #3058593
07/12/22 02:33 PM
07/12/22 02:33 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Not hard to work on. What is wrong with yours?
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: NITROUSN] #3059485
07/15/22 06:18 PM
07/15/22 06:18 PM
Richmond, Indiana
Richmond, Indiana
Sorry- forgot to check back on this.
Mine won't stay in 4 wheel low - it jumps out on its own. I have checked the shift linkage, and it isnt an engagement problem. It also seems like the chain is stretched because in 4wheel high, under load, i have experienced what seems like skipping of teeth or the chain slipping.
My truck has 311,000 miles on it. previous owner rebuilt the trans, but i dont think they touched the transfer case at the same time. I only put a couple thousand miles on the truck each year at this point. I would like to get it working the way it is supposed to - as this is my tow vehicle.
55 Plymouth Project
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: 19swinger70] #3059487
07/15/22 06:24 PM
07/15/22 06:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Most common problem with popping out of low is the shifter. If the shifter pivot bushing is tight you may not be getting into the low range detent. I have fixed many by repairing the shifter and getting the adjustment dead on. If the chain is slipping you should notice it all the time on a hard pull. Again if the shifter is stiff you could be jumping in and out of 4wd.
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: NITROUSN] #3059503
07/15/22 07:51 PM
07/15/22 07:51 PM
Richmond, Indiana
Richmond, Indiana
Ok. Sounds like i need to spend more time troubleshooting it.
55 Plymouth Project
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: 19swinger70] #3059515
07/15/22 08:17 PM
07/15/22 08:17 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If you have an area you can drive it in low range do this. Pop the rod off the lever and make sure it is in low range. Then drive it. If it does not act up you know it was linkage. Then do the same in 4wd high. Again if it works ok it was linkage. If both tests still show issues you know that repairs are needed.
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: NITROUSN] #3059523
07/15/22 08:38 PM
07/15/22 08:38 PM
Richmond, Indiana
Richmond, Indiana
That makes sense. I live on 20 acres - so i can do that.
Thanks!
55 Plymouth Project
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: NITROUSN] #3061451
07/21/22 05:04 PM
07/21/22 05:04 PM
Richmond, Indiana
Richmond, Indiana
Hey man - you were right. The bushings and factory linkage were worn, and not adjusted properly. I had some rod ends and an aluminum sleeve laying around, and I made my own linkage. Now, I can get all the transfer case gears to engage, and stay engaged while driving around. Thanks for keeping me from pulling it out prematurely!
I do need to sink some $$$ into this old girl though. It needs brakes, and I think axle joints. It crab walks pretty bad even in 4H. Even in grass and on gravel.
It is a handy truck to have around when I need to use it!
55 Plymouth Project
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: 19swinger70] #3061469
07/21/22 05:59 PM
07/21/22 05:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Glad it worked out.
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: NITROUSN] #3061605
07/22/22 11:52 AM
07/22/22 11:52 AM
moparx Online content
moparx  Online Content
easy fixes are the best fixes !
i can just imagine me trying to heft around that transfer case. that thing would squash me like a bug !
glad it worked out for you. up
beer
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: 19swinger70] #3062234
07/24/22 10:36 PM
07/24/22 10:36 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I've had to replace the bushings in both ends of the 4WD shifter to transfer case linkage in my 2004 2500 Dodge diesel. I rarely use 4WD in my truck, so the bushings must just be junk. I like your idea on making your own linkage. Is that just aluminum tube and Heim joints? Looks slick! up
Re: Transfer Case Rebuild - '04 1 ton Cummins [Re: JDMopar] #3062777
07/26/22 03:42 PM
07/26/22 03:42 PM
Richmond, Indiana
Richmond, Indiana
Yes- just 3/8" heim joints and aluminum tube. I buy this stuff from McMaster Carr.
55 Plymouth Project
