Re: Slow Progress at Zippy Performance
[Re: ZIPPY]
#3180874
10/04/23 09:39 AM
10/04/23 09:39 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Decent cut and buff progress on the left side.
This is the result from sanding + wool pad and heavy cutting compound And gets me about 90% of what I’m currently capable of doing.
The remaining 10% refinement I can do is from foam and different compounds on the DA polisher. The fender and door has that and the difference is pretty subtle/doesn’t show up easily in a picture.
For an everyday car it’d be ok to stop right here but I’m aiming a little higher.
Left side of the roof is wet sanded and I’ll buff it out tonight.
It’s coming along.
After cut and buff I’m going to rig a temporary fuel system to get it fired up and moved around. I’d like to get it outside in the sun and it needs to reclaim it’s hoist potato status to work the lower body and underbody. I’d started working on getting it running again, got it to crank and got the msd working (multiple things disconnected betweeen Replacing one inner fender and taking the entire dash out)…..but stopped when I decided to repair the quarter extension seams. Mechanical and electrical work is something I want to get back to, but can’t rush this process.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3180889
10/04/23 10:33 AM
10/04/23 10:33 AM
Posts: 10,022 MN
JERICOGTX
MN
Plugging away...
I always finish the buffing process with a waffle pad on the buffer. Never have been able to make the DA buffers work like I want. Everyone has their own methods. Keep the posts coming Rich.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3180904
10/04/23 11:22 AM
10/04/23 11:22 AM
Posts: 4,675 On the parachute mount
n20mstr
What i have found is that when you are done with one step, you really need to wash the area with soap and water to remove all traces of compound. IF it looks good then proceed to the next step. This helps with swirls because it keeps the cutting compound off the surface and off your polishing pads. Also what i have found to work well is, after wool and compound. Make one pass with an older foam polishing pad , with your cutting compound, Also the compound you use makes a big difference. 3m 36060 or 36061 is really good and works great for me. This is silver so honestly you shouldnt need much polishing to make it look good. I like using a DA with a 6.5" foam pad to final polish and even apply wax. Works nice and smoooth
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3180955
10/04/23 01:14 PM
10/04/23 01:14 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
You've really got something to be proud of their Zippy! Looking back to the beginning of the thread, it's amazing what you've accomplished.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Neil]
#3182041
10/07/23 08:05 PM
10/07/23 08:05 PM
ZIPPY
S.E. Michigan
Hey thanks for chiming in guys, sincerely. I have to apologize the last few pictures were pretty rough....they are screenshots of a video clip I'll post the link to. Just like paint and bodywork, it seems no two people do cut and buff exactly the same. The brand of clear coat I used has a forum just like this one and though I did not register, I read everything I could, and I am partially/mostly following the process someone had good luck with that posted about it. A clean surface and tools really is faster, and more efficient....no doubt about it. The build-up of used up compound and clear is the downfall of the old twisted wool pad....that build up and being too heavy-handed with the rotary seems to be the source of most swirls and holograms. I've self trained to use the spur on it but it makes a huge mess and doesn't seem to get all the crud out like washing it does. To get around that I just wash it every so often and I try to use some finesse and a light touch with it/try not to get impatient. 2500 scratches polish up pretty quickly. Right quarter is sanded 800/1000 (nibs and error correction), and all over with 1500 to just below the "eyebrows". Right above and right below those "eybrows" take some extra effort to really clean up. Here's a link to a short video clip... up the volume if you like Eric Johnson.Roof is about half done.
Rich H.
Esse Quam Videri
[Re: HardcoreB]
#3182418
10/09/23 12:23 PM
10/09/23 12:23 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Looking good..Most folks have no idea the work involved in taking on a project like this.
[Re: ZIPPY]
#3182743
10/10/23 01:11 PM
10/10/23 01:11 PM
n20mstr
Why not remove the trunklid?? It would be very easy to buff the trunklid on a stand, and very east to buff the Dutchman panel sitting in the trunk ??
[Re: n20mstr]
#3182798
10/10/23 03:05 PM
10/10/23 03:05 PM
ZIPPY
S.E. Michigan
The thought entered my mind, but the trunk lid was the bane of my existence a few different times during my ownership of the car + happened later in the build as well.
Besides the extensive repairs done on it recently, it also fit poorly ever since I owned the car. This last time around, I had to bend the hinges to adjust it, was a pretty ridiculous procedure...Total gorilla kind of stuff....and at this point I don't want to mess with it any more than I have to.
The trunk lid wasn't part of the last repair, so it still has the first base/clear I put on it from back in July, along with a rough correction that could be refined a little more.
I'm not having a bunch of trouble reaching the center of the dutchman, I have pretty long arms and torso for a guy my height so it isn't too bad.
At this point I think I'd rather put it on a rotisserie than take the trunk lid off LOL. Or go fiberglass trunk lid (I have one kicking around but decided against it).
Rich H.
Esse Quam Videri
[Re: Gabby63]
#3183001
10/11/23 10:22 AM
10/11/23 10:22 AM
ZIPPY
S.E. Michigan
I sure appreciate the positivity and kind comments, thanks.
This thread is not for short attention spans....
Rich H.
Esse Quam Videri
[Re: moparx]
#3187183
10/28/23 09:03 PM
10/28/23 09:03 PM
ZIPPY
S.E. Michigan
Little bit of progress, Finally got it rotated and back on the hoist.
Need to do a little more re-org and then I can start to prep the new underbody metal + correct a few errors below the character line. The underbody work shouldn't be super time consuming as I'm doing epoxy, black single stage urethane and some undercoat.
Also got a little daylight on it, enough to get a good preview and mentally string me along so I'll keep working on it.
Trying to plan a few steps ahead, I brought the gas tank down from the loft where it's been for about a year and a half.
Cleaning the shop and figuring out where to put all this stuff I didn't have before this project is going to take up alot of time. Never thought I'd have a collection of cut/buff/detailing tools and supplies but here we are, now what do we do? Not feeling super creative at the moment so I'm Pretty sure plastic totes will be involved...... Think I'm also going to offload a few things to make some more space.
Rich H.
Esse Quam Videri
