Re: The 541 is headed to the dyno! Any guesses?
[Re: AndyF]
#3061750
07/23/22 12:12 AM
07/23/22 12:12 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Two questions, is there a beehive spring that fits your cam? And what can be done with the tunnelram? Many years ago i had a 535 with 906 heads, picked up .15 et in the 1/4 by hogging out that tunnel ram on it. Those two together might make a big difference. If you have a converter built to 340/hemi specs, it will flash over 3,000 rpm , (3400?) a nd that allows a little leeway in manifold tuning, i would think.
[Re: HardcoreB]
#3064265
08/01/22 10:34 AM
08/01/22 10:34 AM
Posts: 14,504 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
There was a BBM on the dyno here last week. Not a build we contributed to...... just provided the dyno service.
TF heads with their HR springs(PAC 1294), TF HR cam, Howard’s HR lifters(not sure which version), HS 1.5 rockers.
Tthe report I got is things were solid thru 5800rpm, and at 5900 the lifters gave up.
Those heads come set up with the spring installed height at a nominal 1.950”. The specs for the PAC 1294 are 154@1.950/410@1.350.
