Torque on header bolts to aluminum E-heads... #305861
05/02/09 07:51 PM
05/02/09 07:51 PM
Vancouver, WA
MoparMarq Offline OP
Vancouver, WA
I might used the supplied TTI bolts for the headers to the Edelbrock aluminum heads, or maybe some studs. What's the correct torque to use?
And should I use any blue or mild Loctite or is it anti-seize on these things?
Sorry for the dumb question...
Re: Torque on header bolts to aluminum E-heads... [Re: MoparMarq] #305862
05/02/09 07:55 PM
05/02/09 07:55 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I think it is a good idea to use some kind of sealant from steel to aluminum. I use the Permatex anti seize stuff on my header bolts going into my aluminum heads.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Torque on header bolts to aluminum E-heads... [Re: 70sixpkrt] #305863
05/02/09 07:59 PM
05/02/09 07:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Hand snug is all I shoot for.
Re: Torque on header bolts to aluminum E-heads... [Re: Neil] #305864
05/02/09 10:07 PM
05/02/09 10:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Antisieze here also.I use studs where I can fit them.Snug them to about 20 or so.Then resnug them after a few heat cycles.Rocky
Chrysler Firepower
