Re: Inspect your Racecar. It could save you
[Re: JERICOGTX]
#3056747
07/06/22 02:53 PM
07/06/22 02:53 PM
Posts: 13,374 Marion, South Carolina [><]
an8sec70cuda
I'm still partial to the older Weld Alumastar 2.0 two piece rims. I'd love to have a set to go on my cuda, but man they're stupid expensive.
Doug...so glad you caught this early and didn't have a mishap that messed up that beautiful car!
[Re: farmboy]
#3057360
07/08/22 09:35 AM
07/08/22 09:35 AM
Posts: 4,687 Wichita
GY3
Wichita
Years ago, I broke the center out of a five spoke wheel, wrecked my car, and darn near killed me. Use a wheel designed for racing. These period correct events, that specifically say, you can't use a modern race wheel irritate me. Yeah, but those cars are slow!
[Re: dvw]
#3057365
07/08/22 10:06 AM
07/08/22 10:06 AM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
I noticed a few years ago that my Weld draglites ( 15x10 ) were starting to have an oval shape by the lug holes and thats with 5/8 studs that I regularly checked for torque they were however pretty old. I broke 1/2 inch studs years ago and they were only a few years old.. it wasn't pretty and did a lot of damage to my 1/4 panel I switched to 5/8 studs right afterwards. I now have Holeshot wheels on the rear and Weld Aluma Stars that I bought from a friend on the front , they weren't cheap but I bought the two for the price of one new. I really like the look. The Holeshot rear wheels are pretty close in looks to the Alumastars and again they aren't cheap but were custom made for my offset , width and stud size. I bought a pair of Raceline wheels for the front before buying the Weld Alumastars as soon as the arrived I sent them back as the wheels and the boxes they came in both said " Made in China " and they looked cheap.
[Re: Cab_Burge]
#3057369
07/08/22 10:49 AM
07/08/22 10:49 AM
Posts: 16,490 On the run…
BloFish
On the run…
Or some old school Cragars. Polish Super Tricks, maybe Not the heavy chrome steel rim SS with the cast pot metal centers I switch between polished Super Tricks, polished Welds depending on the event. I run E/T mags on the street. Glad you caught it before something bad happened.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: bigdad]
#3057419
07/08/22 02:04 PM
07/08/22 02:04 PM
Posts: 19,479 north of coder
moparx
ET3 makes custom old style wheels. i had them make a set for my "endless project" in a 15x15, with a 4" backspace. it took them roughly three weeks. very nice wheels indeed, but pricey at $1100.00. i am happy with them, however, as to me they are worth every penny, and are made here ! [only drawback was they were made about five years ago, so who knows what the price would be today.]
[Re: moparx]
#3057421
07/08/22 02:19 PM
07/08/22 02:19 PM
11secdart
new jersey usa
Holeshot R3s were a little less than a grand a pair for 15x10 4 1/2 inch back spacing , drilled for 5/8 studs... big selection and easy to deal with.
[Re: 11secdart]
#3057480
07/08/22 07:18 PM
07/08/22 07:18 PM
Posts: 170 Sticky South
Rodenteliminator
Sticky South
My 29.5x11.5 W measures 15 1/4 carcass width on 12in wide Draglites like yours, they fit in my wheel wells with the tubs moved in 3in. on my 67 Bbody it’s snug but clears everything. Doug I should add these are Hoosier’s.
Sorry honey I spent the rent
[Re: Rodenteliminator]
#3057676
07/09/22 02:22 PM
07/09/22 02:22 PM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Bogarts new ( old ) wheels
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: an8sec70cuda]
#3057964
07/10/22 12:29 PM
07/10/22 12:29 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
Doug...so glad you caught this early and didn't have a mishap that messed up that beautiful car! I like the Magnum 2.0's which is what I put on my car.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: dvw]
#3057965
07/10/22 12:34 PM
07/10/22 12:34 PM
6PKRTSE
Motor City
I'm torn on what to do. Will it be something close rear only? Or 4 new wheels? Not sure. Certainly the wheel selected will be a currently produced wheel. For the time being the Welds will work. The 2nd question is will a 12" wheel fit? I'd really like to know what the actual section width of a M/T 10.5Wx31 measures on a 12" rim. Doug I run 29.5x10.5W's on a 12" wheel when not running drag radials . If I remember correctly there are slightly narrower than my drag radials when mounted. Drag radials are on now and measure just over 14-1/2" at the sidewalls. The 10.5W's are 14" with tubes.
[Re: 6PKRTSE]
#3058140
07/11/22 09:08 AM
07/11/22 09:08 AM
an8sec70cuda
Doug...so glad you caught this early and didn't have a mishap that messed up that beautiful car! I like the Magnum 2.0's which is what I put on my car. Those also look awesome! A friend has them on one of his grand nationals.
[Re: dvw]
#3058227
07/11/22 01:23 PM
07/11/22 01:23 PM
Posts: 4,687 On the parachute mount
n20mstr
im confused now.....is this a heads up car or a bracket car ??? Outstanding As Usual .....must be the highly polished rims gliding through the air easier
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3058296
07/11/22 03:49 PM
07/11/22 03:49 PM
Posts: 9,852 MI, usa
dvw
MI, usa
It either runs dial-in or NMCA N/SS index. Most of the dial-in stuff is against S/S and Stockers in either GLSSA or Buckeye Stock Super Stock. Normally we run 1/4 mile. This track is pretty short for quick cars. Thats why this weekend was 1/8. I'm foot braking with no starting line chip, no air shift per N/SS rules against trans brake S/S And NHRA stockers. Pretty competitive. Some real good NHRA guys. This track has a VERY SLOW tree. I should've been bumping in on all the runs. Then I misjudged the stripe and gave up the stripe 1st rd Sunday by .004. In N/SS it will run A/FX (9.00 ) or AA/FX (9.25) index depending on weather and how good the track is. Doug
[Re: dvw]
#3058495
07/12/22 07:43 AM
07/12/22 07:43 AM
n20mstr
It either runs dial-in or NMCA N/SS index. Most of the dial-in stuff is against S/S and Stockers in either GLSSA or Buckeye Stock Super Stock. Normally we run 1/4 mile. This track is pretty short for quick cars. Thats why this weekend was 1/8. I'm foot braking with no starting line chip, no air shift per N/SS rules against trans brake S/S And NHRA stockers. Pretty competitive. Some real good NHRA guys. This track has a VERY SLOW tree. I should've been bumping in on all the runs. Then I misjudged the stripe and gave up the stripe 1st rd Sunday by .004. In N/SS it will run A/FX (9.00 ) or AA/FX (9.25) index depending on weather and how good the track is. Doug Thank you for the explanation, but you not getting it (I know what you race in )....Im just saying this car is Bad A$$ thats all. Its getting faster and faster, and you always seem to do it so sanitary !! Car is immaculate and i have seen it in person. Not many cars look better in person than pictures, but this is one of those cars. Great Job
