Re: Bronze gear wear
[Re: moparx]
#3057366
07/08/22 10:20 AM
07/08/22 10:20 AM
Posts: 4,446 Michigan
MarkZ
Worthy
Worthy
Bronze gear on 20w50 with a standard pump: what time frame/use/passes did that gear have ? my thoughts are, where do the gear particles cause the most damage to the rest of the internals ? 2.5 years, six passes and roughly 3k miles. Cold oil pressure would run 80 PSI. After the change from 20w50 to 10w40 cold pressure is something like 65 and hot idle is 25. Been checking the gear every Spring since and it looks like it's wearing OK. Don't drive the car too much anymore though. No idea what the clearances are in the motor. Would have to find the paperwork from the shop.
[Re: Mopar493]
#3062929
07/27/22 09:01 AM
07/27/22 09:01 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
An update to this thread i start. I changed the gear and bushing, i changed to Hughes "melonized" gear and i have drive it for about 800 miles more now and checked it, it has no visible wear at all now on both intermediate shaft gear or the gear on the cam and i drive this engine with a Milodon high volume/high pressure pump, external oiling and Valvoline vr1 20w-50. Hot engine just over 20 psi idle, 2000 rpm just over 40 psi, 3000 rpm 60 psi and so on. Main clearance 0.0033" rods 0.0028" and pushrod oiling aswell as oiling from number 4 cambearing through the rocker shaft. Its running great. Looks nice to me as well.
[Re: Stanton]
#3062944
07/27/22 09:47 AM
07/27/22 09:47 AM
Posts: 3,089 Michigan
A727Tflite
To me the cam looks to be extremely worn in the are area indicated. I've never seen a tooth profile like this. The profile of the cam teeth should match those on the intermediate gear which has a "V" pattern
The teeth have a bevel so it looks like wear. Look at the lowest tooth to the right, down low.
[Re: Stanton]
#3063021
07/27/22 02:15 PM
07/27/22 02:15 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
if it "ain't" making metal (in the oil and oil filter) your probably good: luck: Keep us in the loop please I bought several of those gears for both BB and SB earlier this year and hope to use one on a BB soon
[Re: Stanton]
#3063040
07/27/22 03:29 PM
07/27/22 03:29 PM
Posts: 138 Sweden
Mopar493
Sweden
In that case the cam gear was worn out as new. The gear looks the same when i installed the cam new. See the added pic with the cam installed with a bronze gear, its the same.
[Re: Cab_Burge]
#3063048
07/27/22 03:46 PM
07/27/22 03:46 PM
Posts: 138 Sweden
Mopar493
Sweden
if it "ain't" making metal (in the oil and oil filter) your probably good: luck: Keep us in the loop please I bought several of those gears for both BB and SB earlier this year and hope to use one on a BB soon No metal in oil, but it sure was with the bronze "sacrificial" gear
[Re: Cab_Burge]
#3081964
09/30/22 11:48 AM
09/30/22 11:48 AM
Posts: 138 Sweden
Mopar493
Sweden
if it "ain't" making metal (in the oil and oil filter) your probably good: luck: Keep us in the loop please I bought several of those gears for both BB and SB earlier this year and hope to use one on a BB soon An update again about the melonized gear, i have drive it for another 1200 miles and the melonized gear looks same as new, no visible marks at all, same with the cam gear and nothing in oil or oil filter. So about 2000 miles with the melonized gear so far and no wear at all. I drive the milodon high volyme pump with external oiling and Valvoline vr1 20w-50.
[Re: LAD 524]
#3082228
10/01/22 01:40 PM
10/01/22 01:40 PM
Posts: 138 Sweden
Mopar493
Sweden
Good news, thanks for the update.
I just installed one in mine and fired it yesterday with a new roller cam install.
Will drive a couple of times then pull it to check. Im sure it will be just fine. They are so incredible much better than the bronze gear, no signs of wear after 2000 miles, the bronze was toasted after 600 miles.
[Re: fast68plymouth]
#3082306
10/01/22 04:56 PM
10/01/22 04:56 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
I have been running the Hughes Melonized gear for about 6k miles, I checked it at about 5k & it was like new
[Re: Mopar493]
#3082587
10/02/22 10:09 PM
10/02/22 10:09 PM
Posts: 1,443 Maryland
Dads426
Maryland
I probably go through 1 bronze gear every two years on a 493, HV oil pump, NSS car. My machinist suggested the melonized gear, but when I contacted Hughes, they said it would wear the cam (custom solid roller), so I elected to just stock up on the bronze gears.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
#3082840
10/03/22 01:28 PM
10/03/22 01:28 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I like what I’m seeing here!! Same here... cuz I swapped the dyno-only bronze gear for a Hughes/Crane melonized piece before the engine went back in
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Mopar493]
#3127459
03/08/23 08:18 AM
03/08/23 08:18 AM
Posts: 138 Sweden
Mopar493
Sweden
An update about the melonized drive gear after one season and about 3000 more miles it still looks great. It only has a nice wear pattern. Same with the cam gear.
[Re: Mopar493]
#3127463
03/08/23 08:48 AM
03/08/23 08:48 AM
Posts: 2,516 PA
moparacer
PA
I posted about my wear issues I had awhile back in this thread and I may have found my issue over the winter. I had cam walk from timing cover flex. Welded a support on the cover to stiffen it up so I think that will fix the cam walk. Be interesting to see if the gear wear goes away. I suspect it will.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
