Re: To groove a crank??
[Re: sc4400]
#305197
05/02/09 12:00 AM
05/02/09 12:00 AM
Posts: 6,145 Melbourne , Australia
LA360
I remember seeing it in an article out of a Hot Rod or similar magazine out of the late 60's, never seen it used or referred to since then. AL....
Alan Jones
[Re: Cab_Burge]
#305201
05/02/09 06:39 AM
05/02/09 06:39 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
That theory doesn't hold much credence as grooving the crank 360* in the middle of the journal creates an other area for weakness and potential failure,grooving the bearings gives you the same effect,the only thing either way you cut down on the total bearing surface area.With todays techonology and oils you don't see that much bearing failure.The few bearing failures we have encountered in recent years have all been attributed to some related cause.oil system malfunction,broken parts or lack of proper maintaince.If the bearing material is appropiate,parts are correct demension,oiling is supplied properly,clearences are precise and the engine is maintained,bearing life is not going to be an issue.Usually when bearing failure occurrs some thing unrealated to the bearing or crank journal will be the culprit.
[Re: B G Racing]
#305202
05/02/09 08:40 AM
05/02/09 08:40 AM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
I don't see what the advantage of cutting up a good crank would be, when you could get fully grooved mains that essentially do the same thing.
You'd just wind up with a ruined crank.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: B G Racing]
#305203
05/02/09 08:45 AM
05/02/09 08:45 AM
Posts: 52,972 Romeo MI
MR_P_BODY
With todays technology theres no reason, I know guys that turn their BB to 9000+ rpm (not counting the PS cars)
[Re: MR_P_BODY]
#305204
05/02/09 09:03 AM
05/02/09 09:03 AM
Posts: 447 lake charles, la
sc4400
lake charles, la
My thinking also.....I said the same thing @ weakening the crank. This advisor just smiled and shook his head no. Said very convincingly that the main journals were too big anyhow, and plenty strong. His crewchief was standing right there, and assured me that the motor in his SS mopar (gorgeous car, first class) had this done to its crank. His background includes MANY MANY years of comp. He has made his own blocks! in the past. I've seen his work over the years and it is simply amazing. He is very quiet, not one to push anything on anyone else. Which is why I gave any credibility to this thought. I want to keep an open mind, and not get bogged down in "conventional wisdom". Anyone here that had been a fly on the wall would have opened their mind, only because of this gentlemans background.
Our failed motor is a 543 with a 4.5 crank. Wide groove mains, Dan Olsen pan, dual pickup milodon, proper clearances. Block has had steel cross bolt caps just installed. Rotating assembly is new. Dead in 7 passes. 1,3,6,8, along with #5 main were well done. It showed clear evidence of starvation, yet had 70-75 psi until the last run. It did see 7800 on one pass, when it failed to shift.
We need to make this motor live...so I am keeping an open mind. We may try it.
RIP
[Re: AndyF]
#305207
05/02/09 07:58 PM
05/02/09 07:58 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I am in agrement with most everyone else here as well. It simply isnt necessary. Your guy may have HIS reason, just doesnt make any sense to me. Thats what the grooves in the bearings are for in the first place. There are thousands and thousands of 500+ inch mopar engines running just fine with half groove and like Andy says 3/4 groove bearings and of course full groove, both thin and wide. We used to race a Super Gas Dart, and when we had no other options ( many years ago) I'd take standard P Clevites, and drill for my own dowels due to lack of availability in -.020, and had the same problem with cranks that were -.020 on the mains. Used passenger car P bearings chamfered with no issues whatsoever. Bearing technology and availability has gotten even better, so you have something else going on.
Yours is no different. SOMETHING caused that failure, but certainly NOT the lack of a grooved crank. You need to find the problem.
Jeff is heading in a certain direction perhaps with his question as well.
Your guy has his methods, but in this case, it doesnt sound like a fix for you.
RIP Monte Smith
[Re: n_bogie1984]
#305212
05/02/09 10:27 PM
05/02/09 10:27 PM
Posts: 4,647 aotearoa
rebel
aotearoa
both turn over 8000 rpms for abour 20 sec at a time
wow. i'm guessing you're doing tractor pulls otherwise i would suggest changing your gear ratio.
