Starting truck without a key #3048042
06/05/22 01:41 PM
06/05/22 01:41 PM
AndyF Offline OP
AndyF  Offline OP
I was digging thru some old boxes and came across my old "cheater" harness that I used to use to start my truck when I didn't have a key. My truck was a 1978 and it didn't have a steering lock so I could just plug this harness into the harness on column and then turn the switch. I never figured out all the trucks this trick worked on but it worked on my '78.
Re: Starting truck without a key [Re: AndyF] #3048149
06/05/22 09:56 PM
06/05/22 09:56 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
With the change of the terminal block, it could work on several years of non-tilt columns. The tilt column switch is completely different, and a tilt switch can be plugged into the truck harness and be used with a small screwdriver to slide the stitch in the switch body.
Once you get past 2004, you need the key to make the computer happy.
