Re: 8 1/4 rear bind
[Re: maxwedge1]
#3044640
05/23/22 03:47 PM
05/23/22 03:47 PM
Posts: 3,083 Michigan
A727Tflite
8 1/4 with 3.55 trac-loc. with car off the ground and in neutral the wheels rotate smoothly about 3/4 of revolution then tighten up alot for the last 1/4 turn. both sides equally tight. no noise or grinding just gets very tight. havent pulled cover yet. have been losing fluid at tailshaft of 727 when driving it.. doesnt seem to drip when parked...not sure were its pushing out from..has new bushing and seal from recent rebuild seems to be alot of side movement of yoke/output. could these issues be related??
Why don’t you pull the prop shaft and see.
Re: 8 1/4 rear bind
[Re: maxwedge1]
#3044643
05/23/22 03:55 PM
05/23/22 03:55 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Related I doubt it. How does it turn with the drums off?
Re: 8 1/4 rear bind
[Re: poorboy]
#3044742
05/23/22 11:22 PM
05/23/22 11:22 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If it gets tight each revolution of the tires at the same spot, it's related to the wheels, axles or diff. Pinion, prop shaft and trans turns 3.5 times for every turn of the tires. Get the drums off and see if it goes away, If not, it's in the rear. Pull the cover and take a look.
