Re: Where can I screw in a water temp sensor?
[Re: radar]
#303672
04/30/09 12:42 PM
04/30/09 12:42 PM
It's been awhile, I once drilled and tapped a stock iron 340 intake for this. It SEEMS to me in the back of my mind that someone posted here that a Chibby/ ?Ford/ aftermarket? stat housing has a tapped boss right in the housing.
[Re: sharpie]
#303676
04/30/09 01:09 PM
04/30/09 01:09 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I went electric as well for this reason. My Autometer sensor fits right in. Plus, I don't want boiling coolant hanging out anywhere near my legs....
Where is this boiling coolant around your legs going to come from???? Mechanical temp gauge is not like a oil pressure gauge. The coolant comes nowhere near the gauge, no closer than with the electric gauge.
[Re: MoparforLife]
#303679
04/30/09 03:59 PM
04/30/09 03:59 PM
You do NOT want to use the block drain to take temp readings
[Re: StandOnIt]
#303687
05/01/09 11:09 AM
05/01/09 11:09 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
The adapters have a lip inside so the tube and fitting seal.Most parts places have them.I installed 3 or 4 on SBs and at least 3 on BBs.My local Advance has the adapters.Like a couple of bucks I think.That and drilling the intake if you have to has nothing do do with any metal going into the engine unless you intake is pouring water into the motor.Rocky
Chrysler Firepower
