Re: Fazio with Hoven at ATCO...
[Re: CMcAllister]
#3035749
04/21/22 04:01 PM
04/21/22 04:01 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Hard leaving car off the foot..lol
[Re: CMcAllister]
#3035770
04/21/22 05:36 PM
04/21/22 05:36 PM
Posts: 43,257 Bend,OR USA
Cab_Burge
I'm surprised that car would be legal for NHRA stock, NHRA didn't allowed aftermarket intakes in stock or any modified intakes when I race back in the 1970 to 2000s What say those that know the current rules on intakes allowed in NHRA "stock" now? I use to help two NHRA SS class racers that raced a original 1965 A990 Plymouth Hemi Belvedere SS/BA and a clone 1968 Hemi Dart stick shift SS/A in the late 1980 and 1990s. They were allowed to race with aftermarket manifolds that were approved by NHRA to use in the SS classes back then Both of them set their class records for a short time in the early 1990s
[Re: CMcAllister]
#3035790
04/21/22 06:26 PM
04/21/22 06:26 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
We’ll see if they got the car repaired and are back for another attempt at it this weekend.
[Re: Cab_Burge]
#3035798
04/21/22 06:48 PM
04/21/22 06:48 PM
Posts: 11,645 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Classification guide shows a dual carb race Hemi deal legal for Stock in a factory SS car. Rated at 450HP. Would have to use OE intake and valve lift, no funny business with the heads, among other things. Not sure how but it's there. I'll have to ask folks who do know.
The single four NASCAR combo, rated at 428, has been there. The Carp car used to run that I think.
Different parts allowed on those cars with different engines - steel vs. aluminum, hood scoops, different wheelbases, etc.
[Re: fast68plymouth]
#3035800
04/21/22 06:52 PM
04/21/22 06:52 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
We’ll see if they got the car repaired and are back for another attempt at it this weekend. Blew the tires off first run. Put it on the bumper second. Yes, these cars are adjustable.
[Re: Sammy]
#3035974
04/22/22 11:43 AM
04/22/22 11:43 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Wheelie bars up on the bumper. Not sure if that's the way to go to set a NHRA record. Shouldn't be hard on the bars, or on them at all, when it's right. Not supposed to go that high. Went over center on the chassis when it blew the tires off first run. Hooked and then some on the second.
[Re: CMcAllister]
#3036011
04/22/22 12:50 PM
04/22/22 12:50 PM
fast68plymouth
So. Burlington, Vt.
The big wheelie was last weekend. Resulted in some front end damage....... hopefully they got it all fixed up.
One of my friends is down there...... said there is a little head wind this morning.
#3036297
04/23/22 12:47 PM
04/23/22 12:47 PM
fast68plymouth
So. Burlington, Vt.
I didn’t see Hoven on the q sheet from yesterday.
After thinking about it for a bit....... I doubt they would go for the record at a “Divisional” race, since it would likely result in a HP hit from the AHFS. Last week was an “open”, where the AHFS doesn’t apply.
#3036387
04/23/22 04:28 PM
04/23/22 04:28 PM
Posts: 3,505 DFW
mr_340
DFW
425 426 DP 12.5 2-4 Holl R-3116,4235,4236 (2) 2536768 1.56 I M 167.7 14 1.52 E M Carb sizes - 1686x1686/1375x1437
14 - Alt intake manifold P4532265
Floyd Lippencott IV
[Re: mr_340]
#3036395
04/23/22 04:52 PM
04/23/22 04:52 PM
fast68plymouth
So. Burlington, Vt.
Apparently Todd injured his back when the car came down....... so he’s in recovery mode for a little while.
