Re: Hotchkis uCA
[Re: GoodysGotaCuda]
#3041816
05/12/22 03:58 PM
05/12/22 03:58 PM
Posts: 1,184 clarks summit pa
73cuda340
clarks summit pa
I bought a set for my cuda, I just haven't gotten around to installing them yet. Very nice quality.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: Hotchkis uCA
[Re: 73cuda340]
#3052467
06/22/22 05:03 PM
06/22/22 05:03 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
There is a problem with the newer design UPPER Control Arms... with some rims, if the backspacing is a little deep (and for some cars having wide rims... a deep backspacing is necessary), the newly designed adjusting bolts may hit the inside of the top of the rim or tire upon turning near-to-full lock. This could be avoided IF the new adjusting bolts would be relocated further in towards the engine.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: Hotchkis uCA
[Re: Mopar Mitch]
#3052470
06/22/22 05:14 PM
06/22/22 05:14 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
There is a problem with the newer design UPPER Control Arms... with some rims, if the backspacing is a little deep (and for some cars having wide rims... a deep backspacing is necessary), the newly designed adjusting bolts may hit the inside of the top of the rim or tire upon turning near-to-full lock. This could be avoided IF the new adjusting bolts would be relocated further in towards the engine. Thanks for info. Along those same lines with wide rim with high backspacing, watch out of tire clearance at full lock if you are running the US Car Tool inner fender shock tower supports. I know of an A-body that has that problem and they had to notch the support.
Re: Hotchkis uCA
[Re: autoxcuda]
#3052493
06/22/22 06:33 PM
06/22/22 06:33 PM
Posts: 6,332 nowhere
Sniper
nowhere
When I was mocking things up for my 51 Plymouth wider rims and tires were on the menu. Seeing how no one did this, other than nut cases like me, I had no advice on what fits, or doesn't for that matter. So I thought about it. Minimum rim size was going to be 17's, not much in the way of tall, HP tires in anything smaller. Didn't want to spend a fortune on rims so I went with an OEM rim, in this case a set of steelies from the Challenger/Charger/300 cars. Right bolt pattern, right center hole diameter for hub centricity. But what size tire? Not wanting to spend a fortune on tires for fitment purposes I came up with an idea. Here's what I did http://www.yourolddad.com/tiresI could have gone much wider in the back, but I wanted a square setup. Tire height was picked to match the stick height to minimize speedometer inaccuracies and to allow my to use my new stock tire as a spare as I know it will clear everywhere. Because this is a driver.
Re: Hotchkis uCA
[Re: sogtx]
#3061996
07/24/22 02:37 AM
07/24/22 02:37 AM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
Pretty damn slick
Anyone try yet ?
Those have to be the ugliest UCA I’ve ever seen and I just can’t do ugly that’s why I went with an adjustable Black SPC.
Re: Hotchkis uCA
[Re: sogtx]
#3075313
09/07/22 08:46 PM
09/07/22 08:46 PM
Posts: 29 Illinois/Tennessee
Murfman1967
Illinois/Tennessee
I have them on my 66 Charger with Hotchkis strut rods, torsion bars, sway bars, leaf springs, and shocks. I went with a FF stage 3 steering box, HD tie rods, needle bearing idler arm, and Dr Diff disc brakes with Cobra calipers front and rear. They clear my 17” wheels with zero issues.
99 Ram 2500 QCSB V-10 Stepside 72 Magnum Marine 27' Twin 5.9 Magnums 70 A-100 Sportsman /6 67 Coronet R/T 440 66 Charger 470 53 Plymouth Suburban flathead T-5
Re: Hotchkis uCA
[Re: 70RT Charger]
#3075317
09/07/22 08:59 PM
09/07/22 08:59 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Those have to be the ugliest UCA I’ve ever seen and I just can’t do ugly that’s why I went with an adjustable Black SPC. [/quote] J
