Re: Latest GYC with a rebodied "Cuda"
[Re: topside]
#3030330
04/03/22 04:49 PM
04/03/22 04:49 PM
Posts: 3,267 Connecticut
1972CudaV21
Connecticut
I didn't see where anyone posted on this, sorry if I'm reposting... Apparently a customer bought a "Cuda V-code" and brought it in for restoration, but after looking it over, Worman finds out it's a re-bodied Gran Coupe. Rad support & cowl replaced at some time, GC trim holes welded & ground...someone definitely intended to re-body and "upgrade" the car. OEM dash VIN rivets & apparently pad. Basically called the car out - with the V-code VIN - on national TV, then says the customer wants to proceed with the build. Yikes. Seems to me that's flirting with trouble even further than the mostly-AMD '71 black Cuda build, apparently also a customer request. Well, at least it will be documented on tv as a tainted car.
China is the enemy.
[Re: 1972CudaV21]
#3030335
04/03/22 05:13 PM
04/03/22 05:13 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I didn't see where anyone posted on this, sorry if I'm reposting... Apparently a customer bought a "Cuda V-code" and brought it in for restoration, but after looking it over, Worman finds out it's a re-bodied Gran Coupe. Rad support & cowl replaced at some time, GC trim holes welded & ground...someone definitely intended to re-body and "upgrade" the car. OEM dash VIN rivets & apparently pad. Basically called the car out - with the V-code VIN - on national TV, then says the customer wants to proceed with the build. Yikes. Seems to me that's flirting with trouble even further than the mostly-AMD '71 black Cuda build, apparently also a customer request. Well, at least it will be documented on tv as a tainted car. Assuming that Worman's "investigation" is credible...this guy can't even put a hood decal on in the right location, even with "factory documentation"....
[Re: topside]
#3030368
04/03/22 07:30 PM
04/03/22 07:30 PM
Posts: 43,541 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
My 69 GTS that I have owned for almost 44 years now had the top core support changed in 1979 when I wrecked it into a light pole. There are no numbers on it as my original was destroyed at the place where the numbers were. Lots of cars had that happened to them back in the day. I don't care what anyone says about my car, it is still numbers matching...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3030369
04/03/22 07:32 PM
04/03/22 07:32 PM
Posts: 6,241 nowhere
Sniper
nowhere
My 69 GTS that I have owned for almost 44 years now had the top core support changed in 1979 when I wrecked it into a light pole. There are no numbers on it as my original was destroyed at the place where the numbers were. Lots of cars had that happened to them back in the day. I don't care what anyone says about my car, it is still numbers matching... You might believe that, heck you might be right. You won't get matching numbers money for it though and in the end that is all matching numbers is about.
[Re: topside]
#3030378
04/03/22 07:48 PM
04/03/22 07:48 PM
Posts: 1,236 Fairview Tennessee
SV_MOPARS
Fairview Tennessee
I didn't see where anyone posted on this, sorry if I'm reposting... Apparently a customer bought a "Cuda V-code" and brought it in for restoration, but after looking it over, Worman finds out it's a re-bodied Gran Coupe. Rad support & cowl replaced at some time, GC trim holes welded & ground...someone definitely intended to re-body and "upgrade" the car. OEM dash VIN rivets & apparently pad. Basically called the car out - with the V-code VIN - on national TV, then says the customer wants to proceed with the build. Yikes. Seems to me that's flirting with trouble even further than the mostly-AMD '71 black Cuda build, apparently also a customer request. so they get the car apart and find out it was rebody, then he goes thru with his original plans of building it, what else could he of done at that point?
[Re: SV_MOPARS]
#3030381
04/03/22 07:57 PM
04/03/22 07:57 PM
Sniper
nowhere
I guess that depends on what the owner wanted. If he wanted a numbers match ride, ditch that one and find another. If he wanted a nice period muscle car, carry on.
[Re: Sniper]
#3030402
04/03/22 08:28 PM
04/03/22 08:28 PM
Rhinodart
Rhinotruck
Rhinotruck
My 69 GTS that I have owned for almost 44 years now had the top core support changed in 1979 when I wrecked it into a light pole. There are no numbers on it as my original was destroyed at the place where the numbers were. Lots of cars had that happened to them back in the day. I don't care what anyone says about my car, it is still numbers matching... You might believe that, heck you might be right. You won't get matching numbers money for it though and in the end that is all matching numbers is about. I cut apart a 1968 Dart GT and the core support had no numbers on it whatsoever. It was 100% original and I knew the owner from day one. If you believe every Mopar came from the factory with the proper numbers stamped on them then I have a chunk of nice dry land in Florida I will sell you. I am sure you have seen the factory VIN issues that are out there. A buddy had a 71 "V" code Roadrunner where the "V" was missing in the VIN, only 12 numbers instead of the requisite 13...
A-Body's RULE!
[Re: Rhinodart]
#3030424
04/03/22 09:19 PM
04/03/22 09:19 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
My 69 GTS that I have owned for almost 44 years now had the top core support changed in 1979 when I wrecked it into a light pole. There are no numbers on it as my original was destroyed at the place where the numbers were. Lots of cars had that happened to them back in the day. I don't care what anyone says about my car, it is still numbers matching... You might believe that, heck you might be right. You won't get matching numbers money for it though and in the end that is all matching numbers is about. I cut apart a 1968 Dart GT and the core support had no numbers on it whatsoever. It was 100% original and I knew the owner from day one. If you believe every Mopar came from the factory with the proper numbers stamped on them then I have a chunk of nice dry land in Florida I will sell you. I am sure you have seen the factory VIN issues that are out there. A buddy had a 71 "V" code Roadrunner where the "V" was missing in the VIN, only 12 numbers instead of the requisite 13... About a third to half of the superbirds have no core support stamp. I have seen several 1971 cudas with no cowl stamp, known original undamaged cars, but I have never seen a 71 cuda without the core support stamp. Mistakes did happen. I see no problem here, I know a lot of people do not like Mark, but I see no funny business from him here.
[Re: Sniper]
#3030430
04/03/22 10:15 PM
04/03/22 10:15 PM
Rhinodart
Rhinotruck
Rhinotruck
What I believe is irrelevant, I am not in the market for a numbers matching anything.
What is relevant is the person looking for a numbers matching something and willing to spend the cash to get it.
BTW, when did they start stamping the numbers on the core support? Might be relevant to what you saw, or rather didn't see. I believe 1 Jan 68 is when it was required? I am talking about SO#'s which started in 1967, numbers are numbers whether it is the SO# or the VIN...
A-Body's RULE!
[Re: 4406bbl]
#3030475
04/04/22 07:29 AM
04/04/22 07:29 AM
Posts: 4,920 new berlin wisconsin
Mr T2U
i started to redo a 71 cuda that didn't have any #'s stamped in the cowl or the radiator support. the car was original and wasn't crashed. it was rusty and needed a little new metal, floors, t floor 1/4 panes. i roughed out the car to 80 grit. then started collecting parts and $$ to finish it like i wanted to. then plans changed with impending home purchase so i sold it that way. i did include pics of when i took car apart showing there weren't any #'s on the body. this was pre digital days so no pics on my computer.
perception is 90% of reality
[Re: Rhinodart]
#3030524
04/04/22 10:56 AM
04/04/22 10:56 AM
Posts: 4,672 Wichita
GY3
Wichita
My 69 GTS that I have owned for almost 44 years now had the top core support changed in 1979 when I wrecked it into a light pole. There are no numbers on it as my original was destroyed at the place where the numbers were. Lots of cars had that happened to them back in the day. I don't care what anyone says about my car, it is still numbers matching... You might believe that, heck you might be right. You won't get matching numbers money for it though and in the end that is all matching numbers is about. I cut apart a 1968 Dart GT and the core support had no numbers on it whatsoever. It was 100% original and I knew the owner from day one. If you believe every Mopar came from the factory with the proper numbers stamped on them then I have a chunk of nice dry land in Florida I will sell you. I am sure you have seen the factory VIN issues that are out there. A buddy had a 71 "V" code Roadrunner where the "V" was missing in the VIN, only 12 numbers instead of the requisite 13... My '71 'Cuda was triple stamped with the same (correct) number on the core support. Guy running the stamper must've been bored that day. The rest of the car was a mess as far as spot welds being missed, done improperly, etc.
[Re: formula_s]
#3030542
04/04/22 11:57 AM
04/04/22 11:57 AM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The welds should have been obvious long before the disassembly and dipping.
[Re: topside]
#3033472
04/14/22 10:47 AM
04/14/22 10:47 AM
Posts: 5,317 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Just to be clear: I'm not bashing Worman on this. He clearly exposed an ugly side of our hobby. My thoughts are as follows:
1. Customer's out probably good money for what turns out to be a re-body. 2. Car is now widely known as a re-body, negatively affecting value whatever its future entails. 3. Law enforcement/DMV may have a big issue with this, as is often discussed here. 4. I'd hate to not only be that customer, but to risk further investment if his DMV is inclined to seize the car.
Replacing a damaged upper tie bar is one thing, no problem there legally. But that isn't what happened in this case. Hope it somehow works out, but the lesson of course is to thoroughly inspect big-money cars pre-purchase.
topside....you (as far as Iv'e seen) always give clear, concise, common sense comments in your post's. PLEASE KEEP IT UP! We need more of that on here, and elsewhere as well! I agree Worman did the right thing, exposing this Plymouth,for what it is...or should I say, not is.
Plymouth Makes It!
