Re: Starter Relay
[Re: 440_ci]
#302905
04/29/09 02:14 PM
04/29/09 02:14 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
So are you using a volt meter to test for voltage?
Where do you not have voltage at?
Have you pulled the bulkhead connector to take a look?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: Starter Relay
[Re: 440_ci]
#302912
04/29/09 04:04 PM
04/29/09 04:04 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Well you said you don't have voltage in the interior (Red wire) at the bulk head. I would check for voltage at the connector (opposite of end of the fusable link not at the starter relay) sounds like it fried.
Remove the connector (engine side) and check the voltage at this (of the fusable link) end.
Allen
Re: Starter Relay
[Re: 440_ci]
#302914
04/29/09 04:08 PM
04/29/09 04:08 PM
Posts: 7,759 So Cal
HealthServices
So Cal
It is the wire. It is a special wire that acts like a fuse if there is too much draw on it. ![](http://shop.oreillyauto.com/product_images/img/dor/60394x.jpg) If you buy a generic fusable link from the parts store make sure to also buy one of these pakard 56 terminals. so you can terminate it correctly.
Allen
Re: Starter Relay
[Re: HealthServices]
#302915
04/29/09 04:10 PM
04/29/09 04:10 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Yeah missed that part, too. Check the other end of the fuseable link, not just the end that is on the relay. Check the engine side. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Starter Relay
#302916
04/29/09 04:22 PM
04/29/09 04:22 PM
Posts: 7,759 So Cal
HealthServices
So Cal
If this is bad don't just splice in the replacement part. Take the wire out of the harness and replace this assy. I dunno if the replacement part is available anymore at the local parts store. You may have to make your new ends. This picture is from a ebay ad that is a direct replacement part.
Allen
Re: Starter Relay
#302917
04/29/09 04:33 PM
04/29/09 04:33 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Better yet do the MADD electrical update. Dunno where the link to that one is but I'm sure someone here has it.
Allen
