Re: 383 pistons in 426 wedge
[Re: AndyF]
#302476
04/29/09 03:24 AM
04/29/09 03:24 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
put a blower on it or turbo it. that compression is perfict for either...
I am truckless..
[Re: 6PakBee]
#302480
04/29/09 11:27 AM
04/29/09 11:27 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
a cheaper alternative might be to get a 4.15" cast stroker crank.
kb-silvolte.com shows the #1271 piston (for a 383) as a 1.848" comp height.
1.848+6.76+(4.15/2)= 10.683", or .042" in the hole based on the blueprint height of 10.725" for an RB block.
based on my calculations assuming a .040" head gasket and 88cc heads, you're looking at about 9.96:1 compression
use a largish cam or a wide LSA to make the intake closing point late to bleed cyl pressure, and it should run on pump premium.
[Re: Alexdodge]
#302481
04/29/09 11:36 AM
04/29/09 11:36 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
With these pistons the car is a real dog. Don't know where to go from here. Its only a touring and cruiser but I still would like it to run better than this. Any one have any ideas? Alex
If you want some easier-than-pistons ideas, I'd recommend: 1. Install -516 heads for the closed chambers and smaller valves/ports (higher velocity). 2. Advance the cam a few degrees. If you have a 'big' cam, consider a swap to an RV or stock cam. 3. Put a fast advance curve in the distributor. Due to your total lack of quench, you still might have detonation issues even though your compression is low, you'll just have to see. 4. Make sure you have a dual-plane intake and a smaller-size carb (or maybe a smallblock Thermoquad?). If not, try to find a 413 or 1966 440 intake, they have smaller flatter runners and might give more velocity than a performance intake. They are easily identified because they kinda look like they've been stepped on.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: patrick]
#302482
04/29/09 12:54 PM
04/29/09 12:54 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
better check your math 1.848 + 6.76 + (3.75/2= 1.875) = 10.483 - 10.725 = -.243 About 7 to 1 compression give or take
[Re: Fury Fan]
#302483
04/29/09 12:56 PM
04/29/09 12:56 PM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Dont mean to hi-jack the post,but can you use 426 wedge pistons in a 383 with stock heads,crank and rods?
'71 383HP FJ6 Charger SE
[Re: 71 FJ6 Charger]
#302484
04/29/09 01:20 PM
04/29/09 01:20 PM
Dodgem
Ontario, Canada
Piston part number please?? I think you will find a 426 W piston will stick out of a 383 a couple hundered thou.
