383 pistons in 426 wedge #302465
04/28/09 09:38 PM
04/28/09 09:38 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
One of my other engines is a 426 marine block. When I put this motor together I used 383pistons and 440 connecting rods in it being it is the same bore . So now I'm told that the pistons set low in the cylinders and I probably only have about an 8 to 1 compression. I don't remember how low they sit low compared to the originial 426 pistons. Is it possible to use a very thin set of head gaskets to make up for some of the difference in the piston height to get the compression higher? I don't want to get into shaving the heads. Just an idea.
Thanks, Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302466
04/28/09 09:48 PM
04/28/09 09:48 PM
AndyF Offline
AndyF  Offline
Yeah those pistons are probably 0.200 down in the hole if not more. Unless it is a tow truck motor you might want to pull it down and buy some pistons that are designed to work in that combination.
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302467
04/28/09 09:51 PM
04/28/09 09:51 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the tallest 383 piston has a CH of 1.932 , a sixpak piston has a CH of 2.061 and that puts it .020 in the hole. It's going to cost you almost as much to deck the head on to surfaces as it will to get a correct CH piston .
Re: 383 pistons in 426 wedge [Re: AndyF] #302468
04/28/09 09:51 PM
04/28/09 09:51 PM
Eastern ohio
Eastern ohio
With these pistons the car is a real dog. Don't know where to go from here. Its only a touring and cruiser but I still would like it to run better than this. Any one have any ideas?
Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302469
04/28/09 09:53 PM
04/28/09 09:53 PM
JohnRR Offline
JohnRR  Offline
Thats where the problem comes in, just can't find anyone that sales them anymore. Alex
call Bob Mazzolini or you can have Diamond make you a set .
Re: 383 pistons in 426 wedge [Re: JohnRR] #302470
04/28/09 09:57 PM
04/28/09 09:57 PM
Eastern ohio
Eastern ohio
Would anyone have a address for these people?
Thanks, Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302471
04/28/09 10:02 PM
04/28/09 10:02 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
http://www.bobmazzoliniracing.com/
I went and got a Hemi block from him a few years ago, great to deal with
Re: 383 pistons in 426 wedge [Re: OzHemi] #302472
04/28/09 10:06 PM
04/28/09 10:06 PM
Eastern ohio
Eastern ohio
I'll check them out, thanks, Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302473
04/28/09 10:30 PM
04/28/09 10:30 PM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
show us your 383 pistons, you can always put in a longer rod. Steve
Engine by DeTar http://www.kansasbadman.com
Re: 383 pistons in 426 wedge [Re: CH3NO2] #302474
04/28/09 11:15 PM
04/28/09 11:15 PM
Eastern ohio
Eastern ohio
A longer rod? I already have 440 rods in there now.
Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302475
04/29/09 01:18 AM
04/29/09 01:18 AM
AndyF Offline
AndyF  Offline
A Hemi rod is longer than a 440 rod but might not be set up for the same pin. Only good solution is to get the right pistons so you can get the compression back up to 9.5 or 10:1 or whatever it is that you want to run.
Re: 383 pistons in 426 wedge [Re: AndyF] #302476
04/29/09 03:24 AM
04/29/09 03:24 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
put a blower on it or turbo it. that compression is perfict for either...
I am truckless..
Re: 383 pistons in 426 wedge [Re: 340SHORTY] #302477
04/29/09 08:13 AM
04/29/09 08:13 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
hughe's has oem 426 street wedge pistons.
Re: 383 pistons in 426 wedge [Re: lewtot184] #302478
04/29/09 09:44 AM
04/29/09 09:44 AM
Eastern ohio
Eastern ohio
Yes!!! Hughs Engines has an assortment of 426 wedge pistons in stock. Thanks, Alex
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302479
04/29/09 10:41 AM
04/29/09 10:41 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Thanks, Alex
8:1 with what heads? If you are running the stock 516's I doubt it would be that low. With 906's I'm guessing it would be close. I would think a set of 915's would be a good option. Again not running the numbers, just guessing.
Re: 383 pistons in 426 wedge [Re: 6PakBee] #302480
04/29/09 11:27 AM
04/29/09 11:27 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
a cheaper alternative might be to get a 4.15" cast stroker crank.
kb-silvolte.com shows the #1271 piston (for a 383) as a 1.848" comp height.
1.848+6.76+(4.15/2)= 10.683", or .042" in the hole based on the blueprint height of 10.725" for an RB block.
based on my calculations assuming a .040" head gasket and 88cc heads, you're looking at about 9.96:1 compression
use a largish cam or a wide LSA to make the intake closing point late to bleed cyl pressure, and it should run on pump premium.
2017 Grand Cherokee Overland
Re: 383 pistons in 426 wedge [Re: Alexdodge] #302481
04/29/09 11:36 AM
04/29/09 11:36 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Alex
If you want some easier-than-pistons ideas, I'd recommend:
1. Install -516 heads for the closed chambers and smaller valves/ports (higher velocity).
2. Advance the cam a few degrees. If you have a 'big' cam, consider a swap to an RV or stock cam.
3. Put a fast advance curve in the distributor. Due to your total lack of quench, you still might have detonation issues even though your compression is low, you'll just have to see.
4. Make sure you have a dual-plane intake and a smaller-size carb (or maybe a smallblock Thermoquad?). If not, try to find a 413 or 1966 440 intake, they have smaller flatter runners and might give more velocity than a performance intake. They are easily identified because they kinda look like they've been stepped on.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: 383 pistons in 426 wedge [Re: patrick] #302482
04/29/09 12:54 PM
04/29/09 12:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
better check your math
1.848 + 6.76 + (3.75/2= 1.875) = 10.483 - 10.725 = -.243
About 7 to 1 compression give or take
Re: 383 pistons in 426 wedge [Re: Fury Fan] #302483
04/29/09 12:56 PM
04/29/09 12:56 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
Dont mean to hi-jack the post,but can you use 426 wedge pistons in a 383 with stock heads,crank and rods?
'71 383HP FJ6 Charger SE
Re: 383 pistons in 426 wedge [Re: 71 FJ6 Charger] #302484
04/29/09 01:20 PM
04/29/09 01:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Piston part number please??
I think you will find a 426 W piston will stick out of a 383 a couple hundered thou.
