Re: Bump steer question
[Re: ProStDodge]
#302448
04/30/09 08:28 AM
04/30/09 08:28 AM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
Posi-Trac or spool???
I had a worn posi do the same thing to my with a stick car.
Scott
My car became unsafe at the end of last year so I replaced the posi unit with a spool. I also installed new u-bolts and everything is nice and tight with the Caltracs and everything holding the diff. Now I can make it down the track but it is still darting back and forth at each shift, that's why I am looking into the possibility of bump steer.
[Re: mike67net]
#302449
04/30/09 08:32 AM
04/30/09 08:32 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well I guess the easy thing to do is re-install the bumps like Herb said.We can still check your alignment from zero to 3" and check your toe throughout the movement. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#302451
04/30/09 08:40 AM
04/30/09 08:40 AM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
That's what I want to do at this point. I care more about getting down the track safely than trying to shift a little more weight to the rear wheels. When is a good time to call?
Thanks, Mike
[Re: MR_P_BODY]
#302452
04/30/09 08:46 AM
04/30/09 08:46 AM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
I don't know, I don't do my own alignments. My main question was if by adding more front end travel by removing the upper contol arm bushings, could I have created a bump steer situation.
You mean the bump stops.... but yes it COULD add greater bump steer with the added travel. You can do the testing (toe curve) on your own with a tape measure and a couple of straight edges and a floor jack, keep measuring the toe in at .5" intervals all the way up through the travel till the tire lifts off the ground. The correction for the toe differences is moving the inner or outer tie rod locations. If you have the MP Chassis book it show what to do and how to correct it
OOOPS! I feel kind of silly saying upper control arm bushings. I have been wanting to get it re-aligned anyway because I've noticed (from picture) that when the front comes up, the tires look closer at the top than the bottom.
[Re: MR_P_BODY]
#302454
04/30/09 09:20 AM
04/30/09 09:20 AM
Posts: 726 ohio
mike67net
mopar addict
mopar addict
ohio
Thats a design thing from the factory for cornering (the upper A-arm is shorter than the lower
That's normal then? Maybe I should just put the snubbers back in and give it a try. I could just check the toe at the different heights in my garage like you said.
[Re: mike67net]
#302456
04/30/09 10:14 PM
04/30/09 10:14 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Id put the snubbers back in. Without the snubbers your going to have bump steer issues as you have already found out.
The tires being pulled in at the top is a result of the shorter upper A arms. It will pull the tire into negative camber. Along with moving the caster into the negative direction from the built in anti dive swing movement.
Id put the bump stops back in first, but I would also plot out your bump steer as described in the MP chassis manuel to see where its at. mike
[Re: mike67net]
#302460
05/01/09 09:36 AM
05/01/09 09:36 AM
fourgearsavoy
Rittman Ohio
Mike I can probably schedule you in next week some time in the afternoon when we have more time to get it right.Give me a call when the weather is nice or when you you have the time.We just got the latest and greatest Hunter rack that has a bump steer adjustment option. Gus
[Re: HMcCandless_Jr]
#302463
05/01/09 02:47 PM
05/01/09 02:47 PM
Posts: 528 N.W. Indiana
DblOJoe
N.W. Indiana
Oh yea lets not forget the knowledge of Herb McCandless.
We could all use some of that.
[Re: DblOJoe]
#302464
05/01/09 04:49 PM
05/01/09 04:49 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
An old two piece sliding curtain rod with the two L shaped ends makes a nice toe measurement tool.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
