'62 Fury and Valiant - turn signals the same? Update - Nope #3017856
02/22/22 09:22 PM
02/22/22 09:22 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Are the front turn signal housing on the '62 Fury the same as the Valiant? From the pictures I've seen they look the same but was wondering if they'll bolt in?
Re: '62 Fury and Valiant - turn signals the same? [Re: VITC_GTX] #3017945
02/23/22 09:03 AM
02/23/22 09:03 AM
Minn
SportF Offline
SportF  Offline
Minn
Yes they are. The Valiant lenses are amber, AND look much better on the 62 as well!
Re: '62 Fury and Valiant - turn signals the same? [Re: SportF] #3017973
02/23/22 11:20 AM
02/23/22 11:20 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks!!!
I'm missing the entire housing on both sides and I haven't been able to find many parts for the Fury but there are plenty of of these for the Valiant and they are much cheaper!!
Re: '62 Fury and Valiant - turn signals the same? [Re: VITC_GTX] #3022101
03/08/22 09:26 PM
03/08/22 09:26 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
FYI for those may need to know in the future. They are not the same.
I bought a nice pair of front turn signals housing and lenses off ebay for a '62 Valiant to put on my '62 Fury. I couldn't find Fury housings that they didn't want $150 or more for. The Valiant housing and lenses were $50 shipped.
Anyway, they look similar with the exception of the clear lenses on the Fury and yellow on the Valiant but they did not bolt in. The mounting holes in the front valance do not line up to the Valiant parts and the wiring for both the light housings and car had male terminals. Easy enough fix for me, I make some additional brackets to hold the housings in the original location and change the wiring connects on the housing to match the car.
Re: '62 Fury and Valiant - turn signals the same? [Re: VITC_GTX] #3022268
03/09/22 11:05 AM
03/09/22 11:05 AM
Minn
SportF Offline
SportF  Offline
Minn
Well, I stand corrected. I have used the lenses, but I assumed that the housing, which looks the same, was the same. Thanks for that info.
