What flex fan to use. #302218
04/28/09 06:44 PM
04/28/09 06:44 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
Hi all.I have a duster with a 318.Would like to use a fan clutch,but I can't because of radiator I have.What type or brand of flex fan do you use.Right know I have the slant six steel fan 7 blade.
Re: What flex fan to use. [Re: Crabra] #302219
04/28/09 06:50 PM
04/28/09 06:50 PM
MNobody Offline
MNobody  Offline
Most /6 fans i've seen are 4 blade. If you're not running a shroud, a flex fan might no keep it cool enough.
Re: What flex fan to use. [Re: MNobody] #302220
04/28/09 06:53 PM
04/28/09 06:53 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
This /6 had air.That's where the radiator came from
Re: What flex fan to use. [Re: Crabra] #302221
04/28/09 07:02 PM
04/28/09 07:02 PM
not sure on the best: brand/alum or fiberglass but FYI here are part #'s for 2 short clutch fans. trw fc-28 2.75" height, hayden 2765(not sure of height) listed for a jaguar
Re: What flex fan to use. [Re: Crabra] #302222
04/28/09 07:10 PM
04/28/09 07:10 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
The BEST flex-fan to use is the OEM one ...with the rolled-over trailing edge. They WORK ...and they will flatten-OUT at higher rpms .. but they are heavy and can "tax" a v-belt if you want to rpm the engine up-quick.
Re: What flex fan to use. [Re: Crabra] #302223
04/28/09 08:22 PM
04/28/09 08:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Use what you have with a shroud if you are having cooling problems. Also look into the clutch and fan that the fan comes in from the back side of the clutch. the bolt spacing of the fan is different and has a large hole in the center to clear the clutch to water pump flange. may help with clearace.
