My 1971 GE dryer new motor #3018656
02/24/22 10:12 PM
02/24/22 10:12 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Well after all these years motor went bad, had to push start button and rotate drum by hand. So I bought a retro fit ‘direct replacement’ motor. Yea right, wrong. First had to scour the internet for wiring hookup, got that covered. Next the two new belt pully’s were to short so went to my lathe turned the belt end on the longer one down so the short one fit on it, worked fine. Got it all back together then big scraping noise inside found out the motor had slipped out of the front holder-bushing and fan was scraping, turns out the new motor is 1\2 shorter so off comes the back bracket that bolts to bottom of dryer box and holds the belt tensioner. Back down to shop to weld 3/4” piece on and drill the 2 holes to space it over. Works like a top now, maybe get another 50 years out of it. BTW we bought the washer-dryer when we got married in 71. Gaskets went out on washer 20 years ago so we bought a Maytag. 7 hours on this thing, had to let off some steam.
Re: My 1971 GE dryer new motor [Re: cudaman1969] #3018665
02/24/22 10:27 PM
02/24/22 10:27 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
It is always fun trying to get the old updated to new. Luckily we have a washer/dryer scrapper in town and has a lot of older parts on his self's.
Now for your labor.....$35 a hr X 7 hrs = $245.....cheaper than a new dryer and will probably out last the new one as well. up
My Monster are real!
Living within your means makes life pretty easy.
Re: My 1971 GE dryer new motor [Re: 67vertman] #3018669
02/24/22 10:32 PM
02/24/22 10:32 PM
fredericksburg,va
fredericksburg,va
Motor and belt was $160. Plus the dryer will burn you touching the clothes, not with the new dryers
Re: My 1971 GE dryer new motor [Re: 67vertman] #3018671
02/24/22 10:35 PM
02/24/22 10:35 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
1971! Congrats on keeping it going that long.
I'm only at 30 years on our Maytag combo.
So far I've only had to replace the drum rollers. luck
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: My 1971 GE dryer new motor [Re: cudaman1969] #3018677
02/24/22 10:46 PM
02/24/22 10:46 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Still cheaper than new!
Re: My 1971 GE dryer new motor [Re: 67vertman] #3018693
02/25/22 12:59 AM
02/25/22 12:59 AM
fredericksburg,va
fredericksburg,va
Yep and like you said better. Very simple machine not an electronic part in it, all mechanical switches.
