Re: Milodon 31151 vs Milodon 31581
[Re: 4mopower]
#3017641
02/22/22 11:00 AM
02/22/22 11:00 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
The 31151 if you can fit it.
[Re: 440Jim]
#3017719
02/22/22 02:36 PM
02/22/22 02:36 PM
Posts: 4,457 Washington
madscientist
Washington
I wouldn’t run a box pan again unless it was a dry sump.
[Re: Stanton]
#3017768
02/22/22 04:08 PM
02/22/22 04:08 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
Which one is the rear exit versus the top exit? Huh ??? I was thinking that part # was the Milidon pump cover That was my allowed one mistake for this decade
[Re: Cab_Burge]
#3017790
02/22/22 05:57 PM
02/22/22 05:57 PM
Posts: 162 Chicago-area Illinois
4mopower
Which one is the rear exit versus the top exit? Huh ??? I was thinking that part # was the Milidon pump cover That was my allowed one mistake for this decade I was wondering also. 😆
[Re: John Burdine]
#3017791
02/22/22 06:01 PM
02/22/22 06:01 PM
4mopower
Pretty sure the 31151 and 31161 still wont clear the rack on a tube front end. Milodon states it was built for magnum force k members, which mine is similar. Thanks, John
[Re: 4mopower]
#3017832
02/22/22 08:19 PM
02/22/22 08:19 PM
Posts: 16,506 On the run…
BloFish
On the run…
I had to notch my 31151 pan to clear my Flaming River rack, but it works as it should.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: 440Jim]
#3017933
02/23/22 07:26 AM
02/23/22 07:26 AM
4mopower
440jim......
Yes, I have checked that pan out also. Right now just looking at fit and fuction in my application.
