1972 B-Body Z-Bar Question #3017653
02/22/22 11:43 AM
02/22/22 11:43 AM
Highland, Michigan
1972Rallye Offline OP
Highland, Michigan
I'm restoring my 1972 Charger... When I removed and disassembled the z-bar, I found a rubber coated steel rod inside the bar. I have never seen anything in exploded parts list, etc with this bar. Has anybody ever seen this and what could it be for?
Re: 1972 B-Body Z-Bar Question [Re: 1972Rallye] #3017704
02/22/22 02:02 PM
02/22/22 02:02 PM
ca
N
nick24 Offline
nick24  Offline
N
ca
Looks like a backyard repair using heater hose and a metal rod to prevent lateral movement. Maybe a previous owner was missing one or more of the stock parts.
Re: 1972 B-Body Z-Bar Question [Re: nick24] #3017707
02/22/22 02:07 PM
02/22/22 02:07 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
Poor mans torque strap? lol.
Re: 1972 B-Body Z-Bar Question [Re: 68rrunner] #3017717
02/22/22 02:33 PM
02/22/22 02:33 PM
moparx Offline
moparx  Offline
obviously a home grown remedy of some sort, but why ?
how was that positioned in the tube ?
was the ball and bushing[s] intact on the bellhousing ?
possibly something to keep the bushing[s] on the ball from falling off and ending inside the tube ?
beer
Re: 1972 B-Body Z-Bar Question [Re: 1972Rallye] #3017774
02/22/22 04:45 PM
02/22/22 04:45 PM
Lakewood, WA
rick@laysons Offline
Lakewood, WA
Speculation........
I'll bet it was put there to keep the Z-bar on the ball studs.....instead of the wire clip that goes over the tube and secures the white plastic half-bushings in the tube end.
Re: 1972 B-Body Z-Bar Question [Re: rick@laysons] #3017778
02/22/22 05:04 PM
02/22/22 05:04 PM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted by rick@laysons
Speculation........
up iagree
The retaining spring may have been broken or lost when it was worked on before you got the car twocents work up
Re: 1972 B-Body Z-Bar Question [Re: Cab_Burge] #3018009
02/23/22 12:53 PM
02/23/22 12:53 PM
Highland, Michigan
Highland, Michigan
Speculation........
up iagree
That makes a lot of sense. The retainer spring was missing... AND the frame rail bracket was broken but still functional. So... I can toss the mystery rod!
