Front end issue - 1972 B-Body
#3016640
02/18/22 09:55 PM
02/18/22 09:55 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
When I go over 65mph the front end "hops" like it's running on tires with flat spots. I've had 3 different setts of wheels/tires on it and it does the same thing. The front end was completely rebuilt and only has about 10k miles on it.
Possibly related; there is a clunk in the front end when the steering is turned to the left under acceleration from a stop. Like making a left turn from a stop sign.
Any ideas what it could be?
No longer taking $h!t from anyone!
Re: Front end issue - 1972 B-Body
[Re: TJP]
#3016668
02/18/22 11:27 PM
02/18/22 11:27 PM
DUFFMAN
Slantytown
The frame and k-frame are in great shape. I cleaned and painted them myself so I know they're solid. I've checked the torque on the k-frame mounting bolts and they're fine. I've also checked the torque on just about every bolt on the front end and they're all at the proper torque. The front end is solid.
[Re: DUFFMAN]
#3016670
02/18/22 11:29 PM
02/18/22 11:29 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Bad lower ball joint maybe? Do a complete front end inspection. One of your new parts was bad is my guess,, especially if it drove just fine for the 10,000 miles then all of a sudden starts hopping around at 65mph. I agree that it sounds like a tire flat spot OR a separating belt OR an unbalanced tire/wheel.....but if you've had 3 sets of known good new balanced tires/wheels on it, then it's the front end like you think. Maybe even some upper or lower control arm bushings? Just check. The way I used to do it is this 1. Lower ball joints - jack the front end up so tires are just off the ground. stick a strong mop handle or metal bar under the tire and pry upwards feeling for clunks 2. Upper ball joints - jacked up, push/pull really hard in/out on the top of the tire 3. Tie rods - jacked up. push/pull really hard on the left & right side of the tire 4. Bushings - just look. I dont' really have a good trick for that
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: SportF]
#3016728
02/19/22 11:01 AM
02/19/22 11:01 AM
DUFFMAN
Slantytown
I was planning on doing a disk brake conversion anyway. Hopefully I'll find the problem when I swap out the spindles.
[Re: moparx]
#3016899
02/19/22 07:27 PM
02/19/22 07:27 PM
DUFFMAN
Slantytown
It's steers fine. Even when it's thumping at 70mph it goes straight. I can let go of the steering wheel and it drifts slowly right as you'd expect.
[Re: 68rrunner]
#3016962
02/19/22 10:34 PM
02/19/22 10:34 PM
Posts: 15,540 Omaha Ne
TJP
Omaha Ne
My vote is blown tie rod end(s) Those would likely cause a vibration in the steering wheel, We need a better description to try and help. When it's "HOPPING" have you tried the following: 1. Increase speed/ better or worse? 2. Putting it in Neutral and allow it to slow down through the area (MPH) of the problem? 3. Gentle Turn L or R (hard to do at 65MPH) Think 4 lane road lightly traveled 4. Harsh turn L or R under same conditions. 5. Try light steeping on the brake pedal. A: can yo feel the vibration? B: Does it go away. 6. What do you mean by HOPPING?? Body jumping up and down? seat of the pants feeling?
[Re: TJP]
#3017001
02/20/22 01:19 AM
02/20/22 01:19 AM
Posts: 10,234 Someplace you aren't
SomeCarGuy
I think I felt what could be described as a hop when I had a bad wheel bearing up front. Felt only at certain speeds. Usually high speed or when making a hard turn, like a 90 degree turn as OP mentioned.
I just fixed a front end clunk that was trans cooler lines slapping the steering box mount area every so often if things were just right. Car was new to me and last guy gave up trying to find that. Once I felt the slap a few times I homed in on it. That won’t be your hop, but might be your clunk, something like that.
The tips posted for checking a front end are good. I’ll add that years ago I was able to find a bad tie rod or idler or pitman by reaching under the car not jacked up and pulling the steering linkage back and forth. At least I think I did that. Good luck. Let us know how the mystery turns out.
I want my fair share
[Re: SomeCarGuy]
#3017029
02/20/22 09:16 AM
02/20/22 09:16 AM
DUFFMAN
Slantytown
By "hop" I mean the steering wheel vibration feels up and down rather than side to side. It feels like driving on a tire with a flat spot but it doesn't go away.
If it's a bad wheel bearing it should be corrected when I do a disc brake conversion in the spring.
I'll take a look at the cooling lines.
[Re: TJP]
#3017290
02/21/22 10:23 AM
02/21/22 10:23 AM
Posts: 10,763 North Dakota
6PakBee
North Dakota
What is the frequency of the "hopping"? At wheel speed, a fraction of wheel speed?? And I'll repeat what TJP asked, once it starts, does the frequency change with speed or is it constant?
[Re: 6PakBee]
#3017462
02/21/22 07:38 PM
02/21/22 07:38 PM
Posts: 2,924 Calgary, Alberta Canada
a12rag
Uhh, not that this was same thing . . . but - on my 70 Sport Satellite, small block, I installed the power steering pump with everything that was with the car - BUT, it was missing a plate. That allowed the pump to vibrate - caused vibration in the steering wheel, but not the rest of car. Up to about 60mph, all was good, over that the steering wheel would really vibrate in your hand. Turns out that without the plate, the pump was vibrating, and had cracked the mount in such a way, it was keyed together, until you got up the speed/rpm . . .then it would come loose and vibrate !! . . . I went thru the usual, balance front wheels, exchange wheels front to back, check out front end . . . wasn't til I was looking at another small block with power steering that I noticed the missing plate !!! . . .
It's the triangular plate in upper left of pic (Thanks Hoffman's winners circle). . .
[Re: a12rag]
#3017528
02/21/22 10:04 PM
02/21/22 10:04 PM
TJP
Omaha Ne
Must've been a fun one to find
[Re: TJP]
#3017557
02/21/22 11:41 PM
02/21/22 11:41 PM
DUFFMAN
Slantytown
I'll take a look at the cooling lines. So am I to assume you're not currently driving the car? If you are and have a wheel bearing that bad it may damage the spindle as well or lead to other unexpected failures. So I would encourage you, if driving it, to pursue the cause It's currently in storage. Winters are brutal here (Wisconsin) and salted roads destroy old cars. My goal is to be able to take the car on a 200 mile trip in the fall, so I want to be able to start working on the problem when the car comes out in the spring.
[Re: 6PakBee]
#3017558
02/21/22 11:43 PM
02/21/22 11:43 PM
DUFFMAN
Slantytown
What is the frequency of the "hopping"? At wheel speed, a fraction of wheel speed?? And I'll repeat what TJP asked, once it starts, does the frequency change with speed or is it constant? I haven't driven it since October, so I'm not 100% sure but I think the frequency increased with speed. Maybe it's always there but the frequency isn't high enough to notice until about 70mph?
[Re: DUFFMAN]
#3017626
02/22/22 10:17 AM
02/22/22 10:17 AM
6PakBee
North Dakota
When warmth returns to the frozen north and you have a chance to get her back on the road, it sounds like more diagnostics are in order. Will be waiting with bated breath!
[Re: TJP]
#3017646
02/22/22 11:20 AM
02/22/22 11:20 AM
a12rag
Must've been a fun one to find Oh yeah - and the "vibrating" pump at speed, sounded like the engine pinging ! . . . definitely took a while longer than one would think ! One clue was the PS fluid coming out of the vent hole on top of cap - ??? How/Why would it do that ??
