talk me into or out of 17 inch rims
#3003959
01/10/22 10:33 PM
01/10/22 10:33 PM
Andrewh
so I found a set of rims that fit mopars that might be around 300 bucks. 17x8 rims with 0 offset, so 4.5 inch back spacing that is correct for mopars.
I had thought if I found cheap enough rims, I could find cheaper tires in the 17's, but that doesn't seem to be the case.
I currently run 255 60r15's. the equivalent 17 is a 255 50 but it is more than the cooper cobra's I would get in 15's instead.
if I go to a smaller tire, 225 45 r17, I could get away with tires I have never heard of for under 100 bucks a tire. I would have to step up to 120 bucks a tire to get say Dunlop's, which including the cost of rims, again is more than the cobra's.
is it just a wider selection of tires that makes people jump to the bigger rims? do I really care, just changing tires every 7 years or so?
Re: talk me into or out of 17 inch rims
[Re: poorboy]
#3004004
01/11/22 12:59 AM
01/11/22 12:59 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
What the wheels look like and what they are going on would make a huge difference to me. Some stuff the larger diameter wheels just don't look right, but others are OK. Bigger diameter wheels has almost always included higher priced tires, the two seem to go hand in hand.
Without seeing the wheels and the vehicle, the answer is: NO its probably going to look like crap, and its going to ride rougher. What are the overall goals for the car? My Charger does not ride rough. It handles quite well too.
[Re: bigdad]
#3004008
01/11/22 01:29 AM
01/11/22 01:29 AM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
The only way personally that I would put larger wheels on is if I could fill the back side with LARGER BRAKES. To me there's something ugly about little tiny brake discs and brake drums showing behind BIG wheels. One of the things I remember was Audi coming out with a big, fast V8 and the largest wheels and tires that were commonly available were 15". That restricted them from putting bigger brake rotors on because they wouldn't fit inside of a 15" wheel. What the did was flip the caliper to the inside of the disc and make the disc larger. That said to me that larger 16", 17", 18" and 19" wheels were developed to accommodate LARGER BRAKES(discs) and not just for style. Look at feets' MB and the size of the brakes that fill up the entire inside/backside of those big wheel, looks purpose built when you have brakes that match the wheel size. Anything else to me just doesn't look right. One of my cars came with 15" wheels, I put 16" wheels with snow tires on them and it looked okay, not too out of sort but 16" were an OEM option. I decided I would put another new set of summer (not all season) tires on and ordered 17". Got them, put them on the car, the brake discs looked tiny and the car looked PIMP. Off they came didn't even drive 10 feet with them my wife just about threw up and I sent them back and got 16" wheels and tires. Hey just my opinion, everyone has their own taste and your car. Hey get the big wheels and big brakes much safer with good working big brakes. Here's the inverted caliper Audi V8 brake system.
[Re: Andrewh]
#3004011
01/11/22 02:01 AM
01/11/22 02:01 AM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
What car and what wheels? To be honest - to me these days 15" wheels look puny on rides in a lot of circumstances. I'm 53 so not into donks but i really appreciate a bit larger with proper tires.
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#3004014
01/11/22 02:10 AM
01/11/22 02:10 AM
A12
N.E. OHIO, USA
What car and what wheels? To be honest - to me these days 15" wheels look puny on rides in a lot of circumstances. I'm 53 so not into donks but i really appreciate a bit larger with proper tires. What car and what wheels? Best point yet,
[Re: A12]
#3004043
01/11/22 07:25 AM
01/11/22 07:25 AM
Andrewh
this rim on this car just a fair weather cruiser. it has the 11 inch disc up front and the tms rear disc kit. currently wearing 15's. I guess I started looking because there are only 3 choices in 255 60 r15's now. 160 bucks and up. BFG's look good, but handle poorly in the rain. cooper got bought out now, and firestone doesn't even carry the firehawk themselves. I supposed MT is a 4th option, but I never really liked the lettering on those. I saw some inexpensive 16 and 17 inch tires and thought if I could get into wheels cheap enough, why not. but as I tried to find those inexpensive tires, (and maybe it is just right now being bad), I couldn't find any, with manufacture's I knew. so maybe it isn't worth it.
[Re: Andrewh]
#3004044
01/11/22 08:02 AM
01/11/22 08:02 AM
Posts: 5,450 Michigan
oldjonny
Don't argue with me.
17's on this. 225-55-17 on front and 255-50-17 on the rear. When I changed the front brakes to disc, I had to up-size from the factory 14's just because they would not fit. It was hard to find anything in tire options (anymore) for 15's. So, with limited 16's out there, jumped to 17's.
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: Andrewh]
#3004085
01/11/22 12:00 PM
01/11/22 12:00 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
If the goal is less expensive tires, it probably ain't gonna happen. The lowest price on modern tires is usually going to be some kind of a take-off, like police car 18s that required a plug and because of that are no longer fit for police use, half worn takeoff police car tires, and that type of thing. .....used to be widely available on ebay if you're into that kind of thing. I looked, but wasn't into it....
Rich H.
Esse Quam Videri
[Re: Andrewh]
#3004132
01/11/22 01:38 PM
01/11/22 01:38 PM
oldjonny
I'm running 17 x 8" wheels on the back with 255-50-17's and could have actually gone wider on the tires without any issues.
[Re: AndyF]
#3004136
01/11/22 01:41 PM
01/11/22 01:41 PM
Andrewh
I would have to buy the set, and apparently this company is trash to deal with on returns. I have to measure my current rims for the back spacing on them. if I go with the "common" size 17's that places push, it would be a smaller tire anyway than the 255 60's I already run. using https://tiresize.com/wheel-offset-calculator/it says it would be in .55 inches further in anyway. but that is assuming my current rims are 4.5 inch back spacing too.
[Re: Andrewh]
#3004137
01/11/22 01:44 PM
01/11/22 01:44 PM
oldjonny
I had to scrounge some wheels from my buddies to make some trial fits. I think on the rear I ran an 8mm offset. Fronts were zero.
Its not like the old days when you can go to a tire store and they have tons of stuff in stock. I ended up getting everything from Discount Tire Direct. They mounted, balanced and shipped them right to my house for way less than anyone local would do anything. Was a flawless deal.
[Re: oldjonny]
#3004144
01/11/22 02:17 PM
01/11/22 02:17 PM
Posts: 6,246 nowhere
Sniper
nowhere
I am running 17" rims on the back of my 51 Plymouth. P255/50R17 Hankook Z rated tires, I don't need the Z rating but I do want the improvement in traction and handling. I am using a set of new stock steelies for a 2008 and up Charger, Challenger for the rims. Pretty cheap from RockAuto, Dorman 939137. Probably not cheaper than just new 15" Cooper's, but Coopers aren't really performance tires and in my case 255's were never going to fit the stock 15" rims.. Clearances are good, I came up with a way to sort out how to figure max tire size without having to buy tires, mount them and see. http://www.yourolddad.com/tiresComparison between stock tire (middle one) and the replacements I went with.
[Re: Andrewh]
#3004159
01/11/22 02:49 PM
01/11/22 02:49 PM
Sniper
nowhere
yeah, I read up on the charger wheels, but the bolt pattern isn't quite the same. 115 vs 114.3 I mean I guess it works for a lot of people. there are other steelies that dorman makes, that are pretty inexpensive too. Dorman 939137 are 114.3mm, which is 4.499986". 115 is 4.527545"
[Re: Andrewh]
#3004172
01/11/22 03:11 PM
01/11/22 03:11 PM
Posts: 802 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
Interesting topic since I am debating going to the 17" Rallyes from Year One on my 72 RR.
1972 Road Runner
1988 Shelby CSX-T
[Re: Sniper]
#3004186
01/11/22 03:57 PM
01/11/22 03:57 PM
Posts: 19,402 north of coder
moparx
yeah, I read up on the charger wheels, but the bolt pattern isn't quite the same. 115 vs 114.3 I mean I guess it works for a lot of people. there are other steelies that dorman makes, that are pretty inexpensive too. Dorman 939137 are 114.3mm, which is 4.499986". 115 is 4.527545" and the factory wheel stamping process was that accurate.
[Re: Kern Dog]
#3006320
01/17/22 08:55 PM
01/17/22 08:55 PM
Superfreak
Superfreak
I love bigger wheels on the cars, certainly not donk wheels but 17's to max 20's depending on the car. 14's and 15's look so small on these big cars. I say go for it.
[Re: Kern Dog]
#3006435
01/18/22 10:04 AM
01/18/22 10:04 AM
A12
N.E. OHIO, USA
Such a divisive issue. Old school dudes that never take a corner faster than idle speed cling to their tall sidewall BF Goodrich tires. Guys that like their cars to steer and stop better are willing to step outside of that narrow mindset. I whole heartedly agree with your take on it but I don't see my old school GTX being any kind of a "sports car" and the fact is, yes tire performance goes up as the sidewall gets smaller/shorter/lower but ride quality also goes down. I have enough cars in the fleet with 19" and 20" tires but they have much better suspension than a 52+year old muscle car. I don't mind the less performance in a car that has leaf springs and torsion bar suspension, I'll keep the extra sidewall cushion with low 30 psi tire pressure and squirm through the corners thank you. One of the highest performing, no make that the HIGHEST performance cars in the world have been running on 13" wheels for the last four decades up until this year, no problem with steering or braking with really tall sidewalls.
[Re: Kern Dog]
#3006449
01/18/22 10:56 AM
01/18/22 10:56 AM
Posts: 31,029 Oregon
AndyF
Such a divisive issue. Old school dudes that never take a corner faster than idle speed cling to their tall sidewall BF Goodrich tires. Guys that like their cars to steer and stop better are willing to step outside of that narrow mindset. I switched to 17 inch rims on my Coronet back in 1992 and have never regretted it.
[Re: Andrewh]
#3006505
01/18/22 12:52 PM
01/18/22 12:52 PM
Posts: 16,479 On the run…
BloFish
On the run…
It all depends on the look you are hoping to achieve.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3006538
01/18/22 01:55 PM
01/18/22 01:55 PM
moparx
i like pizza cutters in the front, and steamrollers in the rear. not a good combo for handling, but the look i have always liked. just my opinion. your mileage will vary.
[Re: Andrewh]
#3006562
01/18/22 04:09 PM
01/18/22 04:09 PM
AndyF
hadn't thought about that. is the ride that much harsher, no other changes? going from 15's to 17's ?
I only have experience with Feet's hot rod as the other car. but his had so many changes, I couldn't attribute his harsh ride to just tires. The ride is similar to what you would have in a modern car. Firm, but not harsh. I use a 55 series tire so it isn't super low profile. The key is to use good shocks. I highly recommend the Koni adjustable shocks. A set of Koni shocks will last forever on a muscle car and they'll give you a performance sedan type of ride.
[Re: oldjonny]
#3006563
01/18/22 04:09 PM
01/18/22 04:09 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Big wheels on old cars is like taking a young prime John Wayne and Clint Eastwood- and giving them manbuns, tight TIGHT Richard Rawlings blue jeans and a flannel shirt.
Keep old mopars alive.
[Re: Kern Dog]
#3006604
01/18/22 08:38 PM
01/18/22 08:38 PM
Posts: 4,945 WI
Dcuda69
WI
Big wheels on old cars is like taking a young prime John Wayne and Clint Eastwood- and giving them manbuns, tight TIGHT Richard Rawlings blue jeans and a flannel shirt. F A L S E. I agree...false! Got a couple buddies that did some 18s on a Superbee and 17s on a 65 Coronet. Tastefully done it works fantastic! If you do rubber bands for tires on 22s....not so much!
[Re: Dcuda69]
#3006641
01/18/22 11:34 PM
01/18/22 11:34 PM
Posts: 1,680 Raleighwood
2Bad360sfromNC
Raleighwood
Most 15" street tires you can actually find now are the farthest thing from sticky. I like 15s fine, but I can do much harder braking with these 17s before I lock the wheels. I do have the later "cop" 11.75" rotors up front now, but the tires were a bigger help. The biggest braking improvement on a few of my cars has been more traction. Of course they do handle better. The ride is no worse, in my opinion, compared to the 15s--I have stock suspension.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D) 1974 Challenger 360 2012 Challenger R/T 1991 Dakota 5.2
[Re: 2Bad360sfromNC]
#3006649
01/19/22 12:11 AM
01/19/22 12:11 AM
Kern Dog
Granite Bay CA
The ride is no worse, in my opinion, compared to the 15s--I have stock suspension. I have never felt that the cars I've owned with low profile tires rode too harsh.
[Re: Kern Dog]
#3006789
01/19/22 01:41 PM
01/19/22 01:41 PM
Posts: 10,209 Someplace you aren't
SomeCarGuy
I’m considering a set of second wheels due to the discovery of my factory road wheels being bent. I had to get new tires to even drive the car home since those were ancient. I had them mounted and all four are bent significantly. I love the old redlines, so thinking I’d run them locally and have a bigger set for long drives.
On the hub issue, seems the year one 17s should have the specs we need. Not sure I like those rims for some reason. Holley has a set of 15s or 16s that are road wheel look that I considering.
Tire rack has some 16s from American racing that I like, but want a black center instead of gray. Will probably call them and see if they can get them since AR lists those. Using tirerack would save some hassles with the mount and balance. They list several rims as being for plus 1-2 for our cars.
I want my fair share
[Re: Kern Dog]
#3006792
01/19/22 01:49 PM
01/19/22 01:49 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Such a divisive issue. Old school dudes that never take a corner faster than idle speed cling to their tall sidewall BF Goodrich tires. Guys that like their cars to steer and stop better are willing to step outside of that narrow mindset. Or purchase a modern car with suspension and tires designed to compliment one another.
[Re: John_Kunkel]
#3006818
01/19/22 03:06 PM
01/19/22 03:06 PM
Sniper
nowhere
Such a divisive issue. Old school dudes that never take a corner faster than idle speed cling to their tall sidewall BF Goodrich tires. Guys that like their cars to steer and stop better are willing to step outside of that narrow mindset. Or purchase a modern car with suspension and tires designed to compliment one another. Like a Kia?
[Re: Sniper]
#3006819
01/19/22 03:13 PM
01/19/22 03:13 PM
2boltmain
Holland MI Ottawa
One pic below is the equivalent of a Muscle Mopar with 15" wheels . The other is a Muscle Mopar with oversize wheels.
#3006864
01/19/22 05:13 PM
01/19/22 05:13 PM
Posts: 192 Philadelphia
The_Blue_Dodge
Philadelphia
Most 15" street tires you can actually find now are the farthest thing from sticky. I like 15s fine, but I can do much harder braking with these 17s before I lock the wheels. I do have the later "cop" 11.75" rotors up front now, but the tires were a bigger help. The biggest braking improvement on a few of my cars has been more traction. Of course they do handle better. The ride is no worse, in my opinion, compared to the 15s--I have stock suspension. Looks good, what size tires are you running? I'm thinking about those wheels for my car.
[Re: John_Kunkel]
#3006880
01/19/22 05:32 PM
01/19/22 05:32 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
Or purchase a modern car with suspension and tires designed to compliment one another. This kind of undercuts the entire hot rodding philosophy, don't you think?
[Re: Sniper]
#3006893
01/19/22 06:04 PM
01/19/22 06:04 PM
A12
N.E. OHIO, USA
I look at it as three different styles or tastes. 1. Stock, naturally you know what that is. 2. Appropriately Day-2, with 14" or 15" period style wheels, Torque Thrust, Slots, Keystone, Chrome steel, Crager SS, etc., 3, Resto-Mod look, with low profile tires 55, 45, 40 series sidewall, and 17" or larger rims. I'm a Day-2 Old School DUDE because I bought my first Mopar in 1969 and not within the last 15 or 20 years, I ordered my '69 Road Runner in late March of '69 and got wheel covers knowing I was going to order "mag" wheels as soon as I burned off the redline bias rear tires, which didn't take long with 3.91 Suregrip, street races and trips to the track PID and Keystone Raceway. I grew old and set in my ways and never really liked most of the Resto-Mod looks (yes maybe a few) but it really got old when every "bitchin" type TV show's first order of customizing was to add big freaking low sidewall tires and wheels. EVERYONE OF THEM. I'll take a Day-2 look over anything for a '60's early '70's muscle car or even a non-performance car or truck of that era any day.....2. I'm not going with low profile tires on my Day-2 GTX just wouldn't look right to me, seems there are a few other OLD DUDES here that feel the same. Oh and BTW I hate that OLD SoCal word DUDE it's SoDated SoDude please don't call me DUDE (I think this is really a GREEN MOPAR thread in disguise.....I like GREEN MOPARS too )
[Re: Sniper]
#3007084
01/20/22 07:11 AM
01/20/22 07:11 AM
2boltmain
Holland MI Ottawa
In reality, mopar muscle on 15's Last one then Ill stop. Any vintage Mopar when one adds bigger wheels.
[Re: 2boltmain]
#3007135
01/20/22 11:48 AM
01/20/22 11:48 AM
ZIPPY
S.E. Michigan
Meh
Rich H.
Esse Quam Videri
[Re: MarkZ]
#3007170
01/20/22 01:14 PM
01/20/22 01:14 PM
John_Kunkel
Rio Linda, CA
Or purchase a modern car with suspension and tires designed to compliment one another. This kind of undercuts the entire hot rodding philosophy, don't you think? If the goal is handling, get a modern muscle car...if you just wanna cruise and have fun, get a rod or early muscle car.
[Re: John_Kunkel]
#3007358
01/20/22 07:44 PM
01/20/22 07:44 PM
Kern Dog
Granite Bay CA
Or purchase a modern car with suspension and tires designed to compliment one another. This kind of undercuts the entire hot rodding philosophy, don't you think? If the goal is handling, get a modern muscle car...if you just wanna cruise and have fun, get a rod or early muscle car. No. If the goal is to improve on the handling ability of a classic, shorter sidewall tires in a diameter similar to stock is one way to go. I could run a 295-40-15 if someone made that size but it would be a very short tire with large gaps between the tires and the body. No thanks.
[Re: Kern Dog]
#3007591
01/21/22 01:51 PM
01/21/22 01:51 PM
John_Kunkel
Rio Linda, CA
Or purchase a modern car with suspension and tires designed to compliment one another. This kind of undercuts the entire hot rodding philosophy, don't you think? If the goal is handling, get a modern muscle car...if you just wanna cruise and have fun, get a rod or early muscle car. No. If the goal is to improve on the handling ability of a classic, shorter sidewall tires in a diameter similar to stock is one way to go. The analogy that I'm tempted to us is "Lipstick on a pig".
[Re: AndyF]
#3007631
01/21/22 04:18 PM
01/21/22 04:18 PM
MarkZ
Worthy
Worthy
Not as worthless as lipstick on a pig. Mopar muscle can be improved substantially with radial tires, lightweight rims, high quality shocks (Koni), bigger torsion bars, anti-sway bars and various chassis stiffening measures. It takes work and money but it isn't impossible. John knows this. He also knows the OP's goal wasn't to turn vintage iron into something that competes with new iron. He's trolling again. No different than the behavior we saw in the unmoderated section.
[Re: A12]
#3007700
01/21/22 08:01 PM
01/21/22 08:01 PM
Superfreak
Superfreak
[quote=A12]I look at it as three different styles or tastes. 1. Stock, naturally you know what that is. 2. Appropriately Day-2, with 14" or 15" period style wheels, Torque Thrust, Slots, Keystone, Chrome steel, Crager SS, etc., 3, Resto-Mod look, with low profile tires 55, 45, 40 series sidewall, and 17" or larger rims. I'm a Day-2 Old School DUDE because I bought my first Mopar in 1969 and not within the last 15 or 20 years, I ordered my '69 Road Runner in late March of '69 and got wheel covers knowing I was going to order "mag" wheels as soon as I burned off the redline bias rear tires, which didn't take long with 3.91 Suregrip, street races and trips to the track PID and Keystone Raceway. I grew old and set in my ways and never really liked most of the Resto-Mod looks (yes maybe a few) but it really got old when every "bitchin" type TV show's first order of customizing was to add big freaking low sidewall tires and wheels. EVERYONE OF THEM. I'll take a Day-2 look over anything for a '60's early '70's muscle car or even a non-performance car or truck of that era any day.....2. I'm not going with low profile tires on my Day-2 GTX just wouldn't look right to me, seems there are a few other OLD DUDES here that feel the same. Oh and BTW I hate that OLD SoCal word DUDE it's SoDated SoDude please don't call me DUDE (I think this is really a GREEN MOPAR thread in disguise.....I like GREEN MOPARS too ) Dude! that is a nice GTX
[Re: ]
#3007721
01/21/22 09:10 PM
01/21/22 09:10 PM
A12
N.E. OHIO, USA
THANKS, (4-speed, console too, and Bro it has a bitchin factory 8-Track player . Funny too it's a California "E" built and sold car, Norwalk, CA, and numbers yada, yada, yada, can't do resto-mod for sure )
[Re: A12]
#3007761
01/22/22 12:39 AM
01/22/22 12:39 AM
AndyF
One of my favorite Valiants with 17 inch rims and a 427 inch small block. 160 mph on the front straight at PIR (and on the I205 freeway in the Portland area late one night)
[Re: AndyF]
#3007848
01/22/22 01:22 PM
01/22/22 01:22 PM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
One of my favorite Valiants with 17 inch rims and a 427 inch small block. 160 mph on the front straight at PIR (and on the I205 freeway in the Portland area late one night) The red brick!
[Re: Sunroofcuda]
#3007852
01/22/22 01:36 PM
01/22/22 01:36 PM
A12
N.E. OHIO, USA
One of my favorite Valiants with 17 inch rims and a 427 inch small block. 160 mph on the front straight at PIR (and on the I205 freeway in the Portland area late one night) The red brick! Should be: The red "Flying" brick! Looks GREAT and yes I always liked it too. There was a '68 or '69 Dart that was done for autocross/road race wasn't there??
[Re: A12]
#3007858
01/22/22 02:09 PM
01/22/22 02:09 PM
MarkZ
Worthy
Worthy
Was that one of Mopar Action's project cars?
[Re: MarkZ]
#3007997
01/22/22 09:54 PM
01/22/22 09:54 PM
AndyF
Was that one of Mopar Action's project cars? It wasn't an official MA project car but Eberg had a green Valiant that was a project car. The red Valiant was owned by my buddy Tim who lives in the Portland area. I helped with with a bunch of the work on the car and I wrote a few mag articles on the car. He sold the car about 10 years ago and it has bounced around to a few different owners on the west coast.
[Re: MarkZ]
#3008253
01/23/22 05:30 PM
01/23/22 05:30 PM
John_Kunkel
Rio Linda, CA
Not as worthless as lipstick on a pig. Mopar muscle can be improved substantially with radial tires, lightweight rims, high quality shocks (Koni), bigger torsion bars, anti-sway bars and various chassis stiffening measures. It takes work and money but it isn't impossible. John knows this. He also knows the OP's goal wasn't to turn vintage iron into something that competes with new iron. He's trolling again. No different than the behavior we saw in the unmoderated section. Your mini-mind is showing AGAIN. My point was, when you're done "improving" you still have a torsion bar, live axle pig. On subject, some of us like the appearance of the taller sidewalls, same continuing argument like RWL showing versus no. No winners, just personal opinion.
[Re: John_Kunkel]
#3008280
01/23/22 06:51 PM
01/23/22 06:51 PM
MarkZ
Worthy
Worthy
Not as worthless as lipstick on a pig. Mopar muscle can be improved substantially with radial tires, lightweight rims, high quality shocks (Koni), bigger torsion bars, anti-sway bars and various chassis stiffening measures. It takes work and money but it isn't impossible. John knows this. He also knows the OP's goal wasn't to turn vintage iron into something that competes with new iron. He's trolling again. No different than the behavior we saw in the unmoderated section. Your mini-mind is showing AGAIN. My point was, when you're done "improving" you still have a torsion bar, live axle pig. On subject, some of us like the appearance of the taller sidewalls, same continuing argument like RWL showing versus no. No winners, just personal opinion. Then next time lead with details like that instead of making an overly broad statement and declaring it as fact. You're still wrong though as the OP wasn't even remotely asking about taking the chassis to it's limits. Make a broad general statement, double down after being called out and act smug all the way down. Your SOP in the unmoderated section.
[Re: John_Kunkel]
#3008310
01/23/22 08:11 PM
01/23/22 08:11 PM
AndyF
Not as worthless as lipstick on a pig. Mopar muscle can be improved substantially with radial tires, lightweight rims, high quality shocks (Koni), bigger torsion bars, anti-sway bars and various chassis stiffening measures. It takes work and money but it isn't impossible. John knows this. He also knows the OP's goal wasn't to turn vintage iron into something that competes with new iron. He's trolling again. No different than the behavior we saw in the unmoderated section. Your mini-mind is showing AGAIN. My point was, when you're done "improving" you still have a torsion bar, live axle pig. On subject, some of us like the appearance of the taller sidewalls, same continuing argument like RWL showing versus no. No winners, just personal opinion. Well I watched Tim blow the doors off lots of Vipers and Corvettes at Portland International with his Valiant. His Valiant had been heavily modified but it still was a torsion bar suspension up front and a 8.75 out back. Transmission was all aluminum but it was still an 833 four speed. Cast iron 340 resto block with Edelbrock heads and a 650 carb. If we were building that car today it would be EFI and have a 5 or 6 speed transmission but 20 years ago those parts didn't really exist.
[Re: Kern Dog]
#3008487
01/24/22 01:07 PM
01/24/22 01:07 PM
John_Kunkel
Rio Linda, CA
In fact, the OP never stated that "handling" was his goal, more like availability and price was his concern; it was the wannabe Stirling Moss types that interjected improved handling into the discussion followed by the predictable personal insults to anybody that disagrees with the herd.
[Re: John_Kunkel]
#3009004
01/25/22 09:14 PM
01/25/22 09:14 PM
Posts: 701 Northern California
lilcuda
Northern California
Not as worthless as lipstick on a pig. Mopar muscle can be improved substantially with radial tires, lightweight rims, high quality shocks (Koni), bigger torsion bars, anti-sway bars and various chassis stiffening measures. It takes work and money but it isn't impossible. John knows this. He also knows the OP's goal wasn't to turn vintage iron into something that competes with new iron. He's trolling again. No different than the behavior we saw in the unmoderated section. Your mini-mind is showing AGAIN. My point was, when you're done "improving" you still have a torsion bar, live axle pig. On subject, some of us like the appearance of the taller sidewalls, same continuing argument like RWL showing versus no. No winners, just personal opinion. Two questions: 1. Have you ridden in or driven The Red Brick Valiant? If not, you have no basis for calling it a "torsion bar, live axle pig". I can tell you from personal experience that the car is no "pig", it is THE most exciting car I have ever owned. 2. If Mopars are (as you put it) "torsion bar, live axle pigs", why are you on a Mopar-specific forum?
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: Kern Dog]
#3009113
01/26/22 10:15 AM
01/26/22 10:15 AM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I don't mind this. I'm not fond of that style of wheel and I think there could be a larger combo to fill the rear wheel opening a little more but all in all, I like it.
[Re: lilcuda]
#3009284
01/26/22 03:51 PM
01/26/22 03:51 PM
John_Kunkel
Rio Linda, CA
Not as worthless as lipstick on a pig. Mopar muscle can be improved substantially with radial tires, lightweight rims, high quality shocks (Koni), bigger torsion bars, anti-sway bars and various chassis stiffening measures. It takes work and money but it isn't impossible. John knows this. He also knows the OP's goal wasn't to turn vintage iron into something that competes with new iron. He's trolling again. No different than the behavior we saw in the unmoderated section. Your mini-mind is showing AGAIN. My point was, when you're done "improving" you still have a torsion bar, live axle pig. On subject, some of us like the appearance of the taller sidewalls, same continuing argument like RWL showing versus no. No winners, just personal opinion. Two questions: 1. Have you ridden in or driven The Red Brick Valiant? If not, you have no basis for calling it a "torsion bar, live axle pig". I can tell you from personal experience that the car is no "pig", it is THE most exciting car I have ever owned. 2. If Mopars are (as you put it) "torsion bar, live axle pigs", why are you on a Mopar-specific forum? 1. Apples to oranges comparison...a car purpose built vs. changing wheels (the thread topic) to improve handling. BTW, my misunderstood reference to "pig" merely means, no matter how you doll it up, it's still a pig. How many scratch-built cars employ torsion bars, leaf springs and live axles? 2. For the same reason I'm on orphan car forums, I love 'em but recognize their limitations....IOW, what I like doesn't have to be beyond reproach.
[Re: Kern Dog]
#3009285
01/26/22 03:51 PM
01/26/22 03:51 PM
John_Kunkel
Rio Linda, CA
Don't expect a rational response from that guy. He should have been a lawyer for how much he loves to argue. North Dakota.
[Re: John_Kunkel]
#3009367
01/26/22 07:40 PM
01/26/22 07:40 PM
Kern Dog
Granite Bay CA
2. For the same reason I'm an orphan car forums
It doesn't have to be that way. You knowingly alienate people by your abrasive responses. It is as if you get some sense of pleasure from purposely keeping people from liking you. Those that have read your posts know that you are strong on convictions. That is not a bad thing. Having friends does not mean that you have to give up your opinions. A real friend respects your right to have an opposing opinion.
[Re: Andrewh]
#3010424
01/29/22 11:45 PM
01/29/22 11:45 PM
AndyF
those of you running 17's what tire size are you running?
looks like the coopers went up 30 bucks a tire and I can get good years in 17's for 110 bucks plus 60 bucks a rim and it is almost a wash. Depends on the car I'd use 235/55-17 tires on a B or E body car. That should be roughly the same as the biggest tire that the factory put on a B or C body car. For an A body car you might need to go a bit shorter.
[Re: Kern Dog]
#3010602
01/30/22 05:16 PM
01/30/22 05:16 PM
John_Kunkel
Rio Linda, CA
It doesn't have to be that way. You knowingly alienate people by your abrasive responses. It is as if you get some sense of pleasure from purposely keeping people from liking you. Those that have read your posts know that you are strong on convictions. That is not a bad thing. Thank you Dr. Freud. If by "abrasive responses" you mean not being like you, “Vive la différence.” Having friends does not mean that you have to give up your opinions. A real friend respects your right to have an opposing opinion. You seem to make a big issue of being liked and having friends...probably because you're so insecure.
[Re: Kern Dog]
#3010704
01/30/22 11:51 PM
01/30/22 11:51 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
Why go with 17's and only be a donk poser? If your going to mess up the looks of a very attractive old Mopar with dorky donky 17" wheels, why not be a REAL donk?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
