no spark in "run" position. MSD..FIXED!! Thanks!!
#300209
04/26/09 03:04 PM
04/26/09 03:04 PM
Posts: 4,280 Medford OR
FrankenScamp
Medford OR
just wondering where to start w/the test light.
I have NO ballast resistor, running an MSD 6AL. Where should I have juice with the key just "on"?
Thanks!.....Shawn
Re: sparks when cranking, no spark in "run" position. MSD..
[Re: FrankenScamp]
#300210
04/26/09 03:08 PM
04/26/09 03:08 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
The blue with the white trace and the brown must be splice together to power msd.
Basically the IGN 1 and the IGN 2 from your key switch.
Or the Dark blue and the brown wire at your resister
Ign 2 which is what you have hooked up to the MSD right now and is giving it power when you crank only.
You also need IGN 1 to power the MSD (when you release the key) and have it in position IGN1
