'70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? #300133
04/26/09 01:02 PM
04/26/09 01:02 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
I am planning on adding a rear defroster set up with dual rear speakers in my buddy's '70 Cuda.He had bought 2-3 different set ups.Can someone post pictures of what the correct e body set up looiks like and where everything gets installed? Thanks again
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: 44D6PAKCUDA] #300134
04/26/09 01:21 PM
04/26/09 01:21 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
The WORLD FAMOUS BARRELCUDA has it installed as a factory option...
CHECK OUT MY NEW WEB SITE !
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: anlauto] #300135
04/26/09 01:22 PM
04/26/09 01:22 PM
anlauto Offline
anlauto  Offline
I also had original speakers re-coned...
Here's a better shot of the set-up...
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: anlauto] #300136
04/26/09 02:21 PM
04/26/09 02:21 PM
Alan-The 2 harneses,the rear speaker and defroster,are totally seperate correct?Do you know what the part number is for the defrost harness and then I assume there is another harness that plugs into the dash switch? Thanks for the great pics!
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: anlauto] #300137
04/26/09 03:59 PM
04/26/09 03:59 PM
anlauto Offline
anlauto  Offline
Seperate harnesses for sure but I have no idea of the part numbers....
The car is elsewhere in storage so it may be a week or two before I actually get around to checking it out. Sorry.
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: anlauto] #300138
04/26/09 04:07 PM
04/26/09 04:07 PM
No problem Alan.Do you know if anybody is still making the correct size corbin clamps to secure the defroster hose at each end?
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: anlauto] #300139
04/26/09 04:10 PM
04/26/09 04:10 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
From the 70-71 Parts Book
Rear Speaker Wiring - 2983583
Rear Defogger Wiring - 2822529
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: 44D6PAKCUDA] #300140
04/26/09 04:53 PM
04/26/09 04:53 PM
Enjoy life today, It has an ex...
gtx6970 Offline
gtx6970  Offline
What size are they?
I can get them up to approx 3-1/8" ID in yellow zinc . Question is going to be how many will sell out of the 1000 pieces required to buy them
Enjoy life today, It has an expiration date
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: gtx6970] #300141
04/26/09 05:01 PM
04/26/09 05:01 PM
Bill-I they are 2 1/2" diameter
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: 44D6PAKCUDA] #300142
04/26/09 05:07 PM
04/26/09 05:07 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Only one corbin is used.
Jules
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: JulesdaWiperman] #300143
04/26/09 05:10 PM
04/26/09 05:10 PM
Jules-Just on the blower end? The shelf vent does not get one?This would explain why there was only one in his NOS kit.Interesting.Thanks!!
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: 44D6PAKCUDA] #300144
04/26/09 06:25 PM
04/26/09 06:25 PM
super gas
super gas
Jim,
the other way around. Clamp is on the vent end. None on the blower.
Jules
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: JulesdaWiperman] #300145
04/26/09 06:45 PM
04/26/09 06:45 PM
anlauto Offline
anlauto  Offline
Jim,
Jules
That's good I thought you were going to say mine was wrong...
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: anlauto] #300146
04/26/09 06:51 PM
04/26/09 06:51 PM
super gas
super gas
Nope. Yours is right alan.
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: 44D6PAKCUDA] #300147
04/26/09 08:01 PM
04/26/09 08:01 PM
cataclysm80 Offline
cataclysm80  Offline
I think the tough part will be finding the switch & bezel with the defog lettering.
Nice pics Alan!
Tav
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: cataclysm80] #300148
04/26/09 08:10 PM
04/26/09 08:10 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
All set there since he got this NOS unit.
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: mccannix] #300149
04/26/09 08:57 PM
04/26/09 08:57 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
What holds the hose to the blower housing end?
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: In_The_Pink] #300150
05/02/09 06:04 PM
05/02/09 06:04 PM
Does anyone have a picture of the correct wiring harness from the defroster motor and resistor to the rallye dash switch? Is anyone repopping it? Thanks !!
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers?? [Re: 44D6PAKCUDA] #300151
05/03/09 06:39 PM
05/03/09 06:39 PM
Can someone tell me if on the dash switch end of the harness,beside the plug that the switch plugs into,is there also a round bullet type connector that maybe plugs into one of the 3 prong underdash accessory plugs? Thanks for any help
Re: '70 Cuda Rear Defroster Set Up w/Dual Rear Speakers [Re: 44D6PAKCUDA] #300152
05/03/09 06:52 PM
05/03/09 06:52 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
Hi Jim
There is a bullet connector as you have described. The part of the accessory harness that goes to the switch looks almost like 1/2 of a '70 'Cuda roadlamp underdash harness, right down to some of the green wires. I'll see if I can find some for pics - should have a few here.
