Re: Shop interior color
[Re: boomerodell]
#3001322
01/02/22 09:45 PM
01/02/22 09:45 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I am in the process of going through the same. I have OSB on the bottom 8 feet and metal above that. I am going with glossy white on the OSB and the ceiling is white. I considered gray on the metal part of the walls to break it up but ended up going white everywhere.
I researched the paint options a lot. Ended up with Sherwin Williams Pro Block primer and Sherwin Williams water based alkyd urethane. It is more durable than latex and really did not cost me much more than good latex paint would have. I ended up going through a Sherwin Williams commercial store. I needed 15 gallons of pant.
[Re: Sniper]
#3001393
01/03/22 10:16 AM
01/03/22 10:16 AM
Posts: 10,717 North Dakota
6PakBee
North Dakota
Going to disagree that satin anything is a good choice in the shop. I would point out that that if you go with the metal interior liner panels, the white will be a satin white, not gloss. At least from the vendors that I had access to.
[Re: 6PakBee]
#3001914
01/04/22 11:29 AM
01/04/22 11:29 AM
Posts: 6,250 nowhere
Sniper
nowhere
Going to disagree that satin anything is a good choice in the shop. I would point out that that if you go with the metal interior liner panels, the white will be a satin white, not gloss. At least from the vendors that I had access to. Yes, satin is good for not having to worry about cosmetic issues for the factory. For actual use it is a poor choice to keep clean.
[Re: boomerodell]
#3014898
02/13/22 05:47 AM
02/13/22 05:47 AM
Posts: 1,965 ID/MT
Cheeto
ID/MT
...The building is 3600sqft with 16' walls ... The thermostat is kept @70. The actual temp is around 68 at working height but like 90 upstairs I do want to try a couple fans in the attic and see how that works. ... I'd plan on getting something set up to move the air around more. That's a lot of space for a single unit mounted high and in one corner. You might run into "overheat" issues with the unit even though the temp on the floor is moderate. I have a buddy in the business and we were just talking about this problem a shop near Rathdrum (sounds like you're in the same climate zone) was having. They installed a fan blowing air from the floor up towards the back of the unit. Where is your thermostat in relation to the unit? As for the walls....do it right now so you don't have to move all that shelving/equipment/etc to do it again in a few years. My $.02...not that I follow my own advice.
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: Alaskan_TA]
#3015350
02/14/22 01:38 PM
02/14/22 01:38 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
How the H E double hockey sticks do you get 500 lic plates??
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
