69 B-Body Sway Bar and Gravel Pan Bolts/Nuts #299826
04/26/09 09:05 AM
04/26/09 09:05 AM
Massachusetts
LYNCHROAD69.5 Offline OP
Massachusetts
Can anyone post pictures (or description...size, thread, washer ect) of the correct sway bar and gravel pan bolts for 69.5 RR. Also, I know the gravel pan has 6 bolts but do all the bolts get U-nuts?
Re: 69 B-Body Sway Bar and Gravel Pan Bolts/Nuts [Re: LYNCHROAD69.5] #299827
04/26/09 11:23 AM
04/26/09 11:23 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
sway bar bolts are a 3/8-16 black phosphate bolt and nut.
I'm just not 100% certain if the bolt did or didn't have a captive washer on it
splash pan bolts are 1/4-20 with a captive washer with yellow zinc captive washer nuts on the inside
Re: 69 B-Body Sway Bar and Gravel Pan Bolts/Nuts [Re: gtx6970] #299828
04/26/09 07:33 PM
04/26/09 07:33 PM
Massachusetts
Massachusetts
Bill, thanks!
Re: 69 B-Body Sway Bar and Gravel Pan Bolts/Nuts [Re: gtx6970] #299829
04/26/09 07:43 PM
04/26/09 07:43 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The sway bar bracket bolts have a captive washer. No washers on the nuts.
