SBC Question
#2997831
12/23/21 11:30 AM
12/23/21 11:30 AM
Posts: 10,755 North Dakota
6PakBee
North Dakota
Okay, go ahead and flame me but I know some of the members have experience with small block Chevy motors. And no, I am NOT going to join a Chevy forum to ask one question. With that said, the early SBC (early/mid 60's) PCV oil separators that went in the lifter galley, how effective are these at removing oil mist? Please don't ask why I want to know, I'm having one of those moments!
Re: SBC Question
[Re: TJP]
#2997993
12/23/21 07:57 PM
12/23/21 07:57 PM
Posts: 1,848 South Bend
John Brown
South Bend
Those cans located in the valley are there to keep the big chunks of oil from getting out through the draft tube, or the PCV valve when so equipped on the mid to late 60's engines that pulled air from the vent at the rear of the block next to the distributor. They worked adequately from my experience after seeing what happened if the under valley can was left out either by accident, or because of a person not knowing why the separator can needed to be there in the first place. When a PCV valve was hooked up to the rear vent without that can installed, an instant smoke screen occurred. Never saw what effect a can being left out, or if I did I didn't notice, any smoke or oil loss on a car equipped with a road draft tube.
Re: SBC Question
[Re: Dabee]
#2999001
12/27/21 08:23 PM
12/27/21 08:23 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I'm guessing you're looking at an aftermarket intake manifold and discovered it hits the top of the separator. I'd run into that at least a couple times.
Otherwise you set it aside when you disassembled the engine and now can't find it. Done that too.
The down draft tubes don't pull the kind of vacuum a PCV valve will on a healthy engine. Early ones used to have a rubber grommet that fit where the downdraft tube hooked up, had a right angle fitting in it which would hook up to a PCV valve using rubber hose.
I was always concerned about pulling oil out of the valley, so would put a frost plug in the hole mentioned above. Remove the separator. Use aftermarket valve covers with the PCV hookup, but make sure there's a baffle on the inside of the valve cover. Some of the cheap ones don't, and I've had trouble with them allowing oil mist to be drawn out of the valve cover.
Hope this helps.
Lead, follow or get the hell out of the way
