New product - low mount 90A alternator #2829591
10/07/20 12:20 AM
10/07/20 12:20 AM
AndyF Offline OP
AndyF  Offline OP
I mocked this up on my Coronet a while back but finally got all the parts in stock to start selling the kits. This bracket kit mounts a 90A alternator from a Toyota Land Cruiser to a BB Mopar. I have brackets that will fit either the RB or the B engine. The alternator fits a little better on an RB engine since there is more space but it will work on the B too. It is a low mount kit so the fuel pump has to go. I designed this for EFI engines since EFI requires a high quality modern alternator to work properly and an EFI engine doesn't have a mechanical fuel pump but it will work with a carb as long as the mechanical fuel pump has been removed. Here is a link to the website: http://arengineering.com/products/90-amp-low-mount-alternator/
Re: New product - low mount 90A alternator [Re: AndyF] #2829595
10/07/20 12:25 AM
10/07/20 12:25 AM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
I like it. Can you get the alternator with a Dayco belt compatible pulley?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: New product - low mount 90A alternator [Re: AndyF] #2829727
10/07/20 11:17 AM
10/07/20 11:17 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Very nice.
Re: New product - low mount 90A alternator [Re: AndyF] #2829848
10/07/20 02:48 PM
10/07/20 02:48 PM
USA
rftroy Offline
rftroy  Offline
USA
Andy,
I looked on the Denso company website, and the non-affiliated DENSOProducts.com website, and they both show 210-0177 as having a two groove pulley.
Over the past decades, I've never measured to see if the location of the inner groove of a two groove pulley is in the same place as a one groove pulley.
Is this the case so that the two groove will work with your setup, or do I need to replace the pulley?
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: New product - low mount 90A alternator [Re: rftroy] #2829872
10/07/20 03:17 PM
10/07/20 03:17 PM
AndyF Offline OP
AndyF  Offline OP
The 210-0177 comes with a two groove pulley and the kit is designed to work with the inner groove. There might be one groove pulleys that you can use but of course a person would need to verify the fit.
Re: New product - low mount 90A alternator [Re: AndyF] #2996095
12/17/21 12:11 PM
12/17/21 12:11 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
@AndyF
Do you make a bracket for the small block with this 90 amp alternator? Or can I modify the spacer on the current bracket kit for the 60 amp unit?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: New product - low mount 90A alternator [Re: mopardude318] #2996106
12/17/21 12:33 PM
12/17/21 12:33 PM
AndyF Offline OP
AndyF  Offline OP
Originally Posted by mopardude318
@AndyF
No I didn't bother since there is an OEM setup for SB engines with a late model high output alternator.
