Re: good/bad of this gen of Dodge truck?
[Re: geo.]
#3001842
01/04/22 01:15 AM
01/04/22 01:15 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Had to replace calipers on all of my Rams, and '08 Durango. Does anyone know how to make these things not ever get stuck, or at least go farther before it happens? I think you'd have to buy an '08 or older to get leaves on a 1500. Hope it works out for you! Replace the phenolic pistols with stainless, problem solved. Coil springs were introduced to the 1500 in 2019.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#3001863
01/04/22 08:13 AM
01/04/22 08:13 AM
Posts: 2,279 ILLINOIS
volaredon
ILLINOIS
Had to replace calipers on all of my Rams, and '08 Durango. Does anyone know how to make these things not ever get stuck, or at least go farther before it happens? I think you'd have to buy an '08 or older to get leaves on a 1500. Hope it works out for you! Replace the phenolic pistols with stainless, problem solved. Coil springs were introduced to the 1500 in 2019. Had to be earlier than 2019, as this truck I bought is a 12 and has coils all around, no leafs
[Re: volaredon]
#3001868
01/04/22 08:28 AM
01/04/22 08:28 AM
3hundred
Colleyville
Had to replace calipers on all of my Rams, and '08 Durango. Does anyone know how to make these things not ever get stuck, or at least go farther before it happens? I think you'd have to buy an '08 or older to get leaves on a 1500. Hope it works out for you! Replace the phenolic pistols with stainless, problem solved. Coil springs were introduced to the 1500 in 2019. Had to be earlier than 2019, as this truck I bought is a 12 and has coils all around, no leafs Dang, my memory is going, 2009, not 2019. Seems like yesterday...
