Nut for Reverse lamp or Seatbelt lamp Question? #298837
04/25/09 07:49 AM
04/25/09 07:49 AM
USA
Suregrip391 Offline OP
USA
I was wondering if anyone knew if the nut itself was a hardware store item or a specialty nut where I would need to locate a used one? The reverse lamps and seatbelt lamps apparently use the same nut. Anyone know of a vendor then?
Re: Nut for Reverse lamp or Seatbelt lamp Question? [Re: Suregrip391] #298838
04/25/09 10:10 AM
04/25/09 10:10 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I've only seen them sold as assemblies with everything included. GATE AJAR lamps used the same bezel and nut/washer, too...
You could buy a trashed used on on eBay just to get the nut, or buy one from a hardware store, though I doubt you could find one as thin as the original nut.
