383 Build #2986214
11/17/21 08:57 PM
11/17/21 08:57 PM
NY
Beep Beep Offline OP
NY
Can I please get some help with a street build 383.
Bore-4.280
Rod-3.375
Piston-L2315F
The short is together with a flat top piston and it’s .008th in the hole.
Cam is an MP 272 adv & .455 lift & 112 lobe
915 Heads are slightly ported they flow 233 @ 500.
Db4p slightly ported single plane intake
Going to run stock manifolds.
915 Heads are at 83cc after valve job.
I was planning on using Felpro .039 head gasket 4.50 bore
What is a good compression range for this combo? Not sure if I should leave the heads at 83 or cut them.
Street car, 4 spd 3:91 gear
Re: 383 Build [Re: Beep Beep] #2986235
11/17/21 09:54 PM
11/17/21 09:54 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Hi Beep , I did a 69 RR with same cam + pistons + manifolds . 727 Auto with 3.55 sure grip . Block decked .020 , pistons popped OUT .010 , and I used 906 heads with Fel-Pros. The heads CC'd around 88 or 90CC's Stock , Had them cut .040 to get to 80CCs. And to use that 272 Cam had machined down the top of the valve guides boss's down from about 3/4" to 11/16 to give me clearance at max lift . drive I always said it was finally a 10 to 1 383 after all that work . Ran like a Monster . Ronnie
Re: 383 Build [Re: 1969ronnie] #2986269
11/17/21 11:22 PM
11/17/21 11:22 PM
NY
NY
Thanks Ronnie. For the information.
Re: 383 Build [Re: Beep Beep] #2986271
11/17/21 11:35 PM
11/17/21 11:35 PM
Have you look on KB,UEM web site to figure out what compression ratio you will have? They have several different helpful formula for figuring out a lot of things on our motors wrench scope
If not due that next scopetwocents
Knowledge is power up
Re: 383 Build [Re: Cab_Burge] #2986283
11/18/21 12:12 AM
11/18/21 12:12 AM
NY
NY
I have checked various compression calculators. If I cut the heads to 82.5 cc that should get me 9.46:1
Re: 383 Build [Re: Beep Beep] #2986300
11/18/21 02:04 AM
11/18/21 02:04 AM
Boise
Moparteacher Offline
Boise
Why the big bore .039" fel-pro head gasket? Why not the .021" factory type head gasket?
The steel shim head gasket is less expensive, will get you closer to a desirable compression ratio and they work well.
Leave the heads at 83cc and install the correct head gaskets.
I calculate with a .021" gasket at 4.32"gasket bore a compression ratio of 9.8:1
This is a good place to be. Factory was supposed to be 10.1:1
You can shave the heads, but anticipate the possibility of having to shave the intake face of the head and taking some material off the intake manifold (an excellent manifold FWIW). DP4B
Re: 383 Build [Re: Moparteacher] #2986303
11/18/21 02:10 AM
11/18/21 02:10 AM
Boise
Boise
Have you checked every piston at .008" in the hole? And, what's the piston to cylinder wall clearance? Are you running them loose or at about .0035" In other words: Do the pistons rock and what's the deck clearance with the piston rocked. .029" piston to head clearance may be a little tighter than you would like... I would run it, but that's me.
Re: 383 Build [Re: Moparteacher] #2986342
11/18/21 09:49 AM
11/18/21 09:49 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
my speed-pro catalog states; 9.77:1 with 78.5cc chambers and 8.94:1 with 88cc chambers. this assumes a .039 gasket. a .020" steel shim will have the quench distance too tight, a .039" gasket will get quench distance around .045"; assuming block hasn't been cut. if it were me i'd leave the heads at 80+ cc's with a fel-pro 8519 gasket to run pump gas. i did something similar to what you have but used 84cc 906 heads and seems to have worked fine with pump gas.
Re: 383 Build [Re: lewtot184] #2986397
11/18/21 12:49 PM
11/18/21 12:49 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
9.5:1 with iron heads, a smallish cam like the 272/.455, and pump gas is about the max I'd run on the street.
Been there, done that, had to pull timing back on a 3400-lb Duster with AT & 3.23s.
Still ran great, but was octane-limited (Calif 91) and would ping with the usual performance timing curve.
Had that cam decades ago in a basically stock 383 RR restoration, ran nice & was pretty close to stock behavior.
Nowadays I'd run a cam with more modern design.
