B&M Stealth Pro Ratchet #298138
04/24/09 11:11 AM
04/24/09 11:11 AM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
Anyone run this shifter? Good/Bad experiences? I have a proflite valve body (P r/n 1 2 3 n) and I am looking for a compatble shifter.
Thank you!
Re: B&M Stealth Pro Ratchet [Re: Plumcrazyracing] #298139
04/24/09 12:17 PM
04/24/09 12:17 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I have used them in my last 3 cars, Love them. NEVER a missed shift.
I have won several rounds at the track against guys with TurboAction Cheeta shifters going 1st-3rd.
Only improvement I think they could make would be to have a rear exit cable version so you didn't have to route the shift cable around the starter/header area.
Scott
Re: B&M Stealth Pro Ratchet [Re: ProStDodge] #298140
04/24/09 12:26 PM
04/24/09 12:26 PM
Central Coast
P
P
Central Coast
Have you ran the proflite style valve body with this shifter?
Re: B&M Stealth Pro Ratchet [Re: Plumcrazyracing] #298141
04/24/09 02:56 PM
04/24/09 02:56 PM
Central Coast
P
P
Central Coast
Has anyone ran this shifter with a 'clean neutral' or proflite valve body?
Re: B&M Stealth Pro Ratchet [Re: Plumcrazyracing] #298142
04/24/09 05:22 PM
04/24/09 05:22 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
not the B&M shifter but i run the T/A shifter with one. took a lil bit of seat time to stop pulling the shifter too far & into the clean neutral. ended up putting a bit of hd tape over the clean neutral on the shifter till i had a handle on it. i'm all good now except my crew can't figure out how to get the car in reverse.
Re: B&M Stealth Pro Ratchet [Re: Plumcrazyracing] #298143
04/24/09 06:00 PM
04/24/09 06:00 PM
Finland
Hessu Offline
Hessu  Offline
Finland
Thank you!
I think if you use neutral safety switch in it. It will start at P and first gear.
I modified my pro ratchet that it start only at P (also have save nautral brake)
