A-body Glide Dipstick #2977517
10/23/21 09:49 AM
10/23/21 09:49 AM
Indiana
dragracer1 Offline OP
Indiana
Hello all, can someone PM me with what dipstick to use on my new powerglide in my a-body Scamp?
BP
Re: A-body Glide Dipstick [Re: dragracer1] #2977559
10/23/21 12:02 PM
10/23/21 12:02 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
A Lokar would work with around a 34" line.You can measure with a rope or wire to check the length for where you want the end. PS: The pic is with the short GM connector but in a 727 and will be close to the same placement.
Re: A-body Glide Dipstick [Re: Clanton] #2977623
10/23/21 04:17 PM
10/23/21 04:17 PM
okla.
sam64 Offline
sam64  Offline
okla.
I bought a powerglide steel tube with locking dipstick and cut out a section of the tube and used 3/4 multi purpose rubber hose to be able to make it go where I wanted it to go. Those Lokar are flexable put are a pain to fill trans through the 1/2 hole in them.
Re: A-body Glide Dipstick [Re: sam64] #2977626
10/23/21 04:24 PM
10/23/21 04:24 PM
Indiana
Indiana
Thanks guys
Re: A-body Glide Dipstick [Re: dragracer1] #2978117
10/25/21 09:07 AM
10/25/21 09:07 AM
PA
moparacer Online content
moparacer  Online Content
PA
Sorry, late in reply but I have always used a lokar in my glide.
Just make sure you double check the fluid level marking. They can be off.
Should be 3/4 inch above the pan rail when its installed in the trans.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
